pkrankow Posted August 29, 2012 Share Posted August 29, 2012 Looks good. How's it work? Phil Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 29, 2012 Author Share Posted August 29, 2012 im seting up it how much must blow air Quote Link to comment Share on other sites More sharing options...
395743 Posted August 29, 2012 Share Posted August 29, 2012 Looks good! Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 29, 2012 Author Share Posted August 29, 2012 can i change the side of bellows i think to up inner tube put down and down inner tube put up because up inner tube is much stronger then down inner tube .up Inner tube is need just for the reserve air and i think up is bigger then down can i replace side will that change something Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 30, 2012 Author Share Posted August 30, 2012 this turn out dont work :angry: can i put this thing on the land can you say me how much air i need not in number but simple how it must blow ANd one blacksmither said me that rubber cant use in forge because it will burn like hell Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 30, 2012 Share Posted August 30, 2012 What is it doing wrong? Phil Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 30, 2012 Author Share Posted August 30, 2012 its falling allways when i put and i can use only down innet tube up inner tube is just reservoar can i use up and down inner tube in same time if i do i can make real good air Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 30, 2012 Author Share Posted August 30, 2012 ok i will take video and show how it wor is it enaugh air i have some sugestion that rubber can get burned and problem is that uper tube is empty no air goes in upper tube i dont know what is purpose of up inner tube Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 30, 2012 Share Posted August 30, 2012 It's not going to get hot enough to burn rubber or cloth if you put some distance between the bellows and the fire. It looks to be on the same level or a little above so flammable gases can't flow back to it. The basics of how a double chamber bellows works. The lower bellows pumps on every stroke, it inflates the upper bellows, the upper bellows supplies the air to the forge in a steady stream instead of pulses like the lower bellows. So, when you work the bellows the upper chamber should inflate and provide air to the fire as it deflates. You can add or subtract weights to increase or decrease air to the fire. A single chamber or one lung bellows can be as simple as a sack and piece of tubing. A bellows this simple requires a person to operate it though so it's not practical for a one man shop. You're making WAY too much of a job out of this, bellows are VERY simple devices and you've been worrying about one for more time than it'd take me to teach you the basics of blacksmithing. Figuring out things like this and tinkering with them till you get something that'll work is a major part of blacksmithing. The craft is largely about figuring new things out. Best of luck. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 31, 2012 Author Share Posted August 31, 2012 i think that is because i put plastic instead of sheet metal on one parit you can see in the midle i put out bellows and i making sheet metal and i will see result Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted August 31, 2012 Author Share Posted August 31, 2012 can you put video of this kinf bellows here is mine is this work good Quote Link to comment Share on other sites More sharing options...
