knifedude1999 Posted August 13, 2012 Posted August 13, 2012 OK I am in my early teens, not rich, and I want to get forging. So that brings me to my question about anvils, could I take a thicker piece of steel weighing like 30 pounds, nail it to a big tree stump and wouldn't that take the beating and a secure connection between the stump and steel should make their weight like one. Let me know if you think this is possible! THX in advance! BTW didn't the vikings use a square of steel with a nail shank on one side in a tree stump as a travel anvil? Quote
Joe Davo Posted August 13, 2012 Posted August 13, 2012 It sounds as if your thinking in the right direction. What your thinking of is what the majority of smiths in the ancient world would have used as you noted with the Vikings. The modern style London pattern anvil has only been around recently in the scheme of things. You only need to make sure you get hard steel as if it is to soft it can begin to dish. In not that experienced so if I'm wrong hopefully someone with more Experiance can correct me. Joe Quote
Fatfudd Posted August 13, 2012 Posted August 13, 2012 Yeah. The connection of the metal to wood will keep the plate from jumping around.You can pound on anything hard, heck rocks were and still are used in many parts of the world. If you are pounding hot metal, soft steel will work for a while until something better comes along. Much is made of using anvil because of the hardness and rebound of the surface plate but you have to go with what you have. you might also try to find a piece of railroad track at a local scrap yard. I used one for many years. Quote
GRiley904 Posted August 13, 2012 Posted August 13, 2012 I use a section of railroad track as previously stated, it work well and was given to me by a friend. I hear a forklift tine is good as well. Quote
ThomasPowers Posted August 13, 2012 Posted August 13, 2012 The more metal directly beneath the hammer the better so a 2" thick piece is better than a 1" thick piece. Cubes are better than plates, etc. A chunk of steel from a piece of heavy machinery can work very well, check for a bulldozer or crane repair facility and see if they will sell you a piece for scrap rate---I once used the broken knuckle off a RR car coupler---weighted about 80 pounds and had a flat surface and a curved surface and did very well! Quote
knifedude1999 Posted August 13, 2012 Author Posted August 13, 2012 THX I'll give it a try soon(week maybe 2) and post pictures....... Quote
Frosty Posted August 14, 2012 Posted August 14, 2012 I had a grand time for a couple weeks with a large axle buried flange up as a field expedient anvil. It worked so well I'm still kicking myself for not pulling it out and bringing it home. Frosty The Lucky. Quote
knifedude1999 Posted August 14, 2012 Author Posted August 14, 2012 I had a grand time for a couple weeks with a large axle buried flange up as a field expedient anvil. It worked so well I'm still kicking myself for not pulling it out and bringing it home. Frosty The Lucky. What was it off of? Quote
SuPahMaN Posted August 17, 2012 Posted August 17, 2012 I just started blacksmithing and so far I have been using this clamp that has a flat part on it and I have been using that as a substitute as an anvil. Its probably 20lbs, not sure, didnt say. Quote
