34557564 Posted July 20, 2012 Share Posted July 20, 2012 Hey all, I have an old Trenton made ACME anvil, around 190 lbs. I like it, but having used a couple of German double horn anvils, I like those a lot better. I really like the flat horn for doing isolated work, and the hardy/ pritchel placement is handy IMO. The only advantage to a London pattern I can think of is the step, and that can be easily remedied by a hardy block (which most people have) or a swage block (which not everyone has). So, what style do you prefer and why? Quote Link to comment Share on other sites More sharing options...
Aaron J. Cergol Posted July 20, 2012 Share Posted July 20, 2012 GERMAN GERMAN GERMAN!!!! The Germans just did things right. For one, they have a hardened plate over the horn, and not just the face like the English did. Also, the square horn as mentioned is wonderful for fine work. The upsetting block no only adds stability, but is obviously quite useful for well...upsetting. They are far more robust that the English and American patterns too. Where an English or American pattern have maybe 1-2" of mass under the hard hole, Germans usually have at least double that, and that's a good thing to make hardies on. I will also note that Austrian anvils will fall into a similar category. I also like various other added features some of the German or Austrian anvils have. Aaron Quote Link to comment Share on other sites More sharing options...
joshua.M Posted July 20, 2012 Share Posted July 20, 2012 I have never used a german pattern anvil, but i would love to, they look so much more useful Quote Link to comment Share on other sites More sharing options...
34557564 Posted July 20, 2012 Author Share Posted July 20, 2012 Another useful aspect I can see is the great mass under the hardy in the German pattern. This way you can upset a hardy tool into the hole without fear of breaking the anvil. Quote Link to comment Share on other sites More sharing options...
Drewed Posted July 20, 2012 Share Posted July 20, 2012 I prefer what ever is in front of me. Quote Link to comment Share on other sites More sharing options...
Don A Posted July 20, 2012 Share Posted July 20, 2012 I use a German (Euro) and like it a lot. I especially like the cone shaped horn as opposed to the rhinosaurus snout on many Londons. Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted July 20, 2012 Share Posted July 20, 2012 Steve Fontanini has designed an anvil which contains some German features, but has an American "rhinoceros horn" style. He moved the upsetting block to the near side assuming a right-hander works with the horn to the left. I don't find the horn shape much matters, as it is used primarily for leverage blows and the bend comes in mid-air beyond the horn contact. I sometimes use the horn as a 'bottom fuller' but the horn shape doesn't bother me. I like the pyramidal horn for tight U bends. It also helps with short bends, because it gives tong clearance on the near anvil side. If a horseshoer draws two side clips, the taper of the horn helps him or her to level the shoe with the clips hanging either side of the pyramidal horn. The hardy hole has lots of mass under it on the Continental anvil, which is good. I don't use the side shelf all that much, but I sharpened mine by grinding/sanding the bottom of it till it was 'sharp' and I use it for forging fork tines and similar shapes. I would say that overall, the Continental two horned anvil has more desirable features than the London pattern anvil. I started forging in the early 1960's when there was no internet and no supplier of anvils except Kennedy-Foster in New Jersey. Little by little, I picked up used anvils, and they were all London pattern. They get the job done and as Drewed stated, you use what's in front of you. Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted July 20, 2012 Share Posted July 20, 2012 An anvil is after all a bottom die or fuller. Different styles or brands may have different surfaces that you may prefer for wot you need when you are forging. The other thing to consider is that you may for no explainable reason just prefer one kind over another. Then yoiu should get that kind. There may be an increase in sasfaction in knowing you have wot you feel is the best. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 20, 2012 Share Posted July 20, 2012 Yes. Definitely! Quote Link to comment Share on other sites More sharing options...
