macbruce Posted July 10, 2012 Share Posted July 10, 2012 I thought this was fasinating because it clearly shows processes alot of us do, just way bigger...... [media=] Quote Link to comment Share on other sites More sharing options...
dan_m Posted July 10, 2012 Share Posted July 10, 2012 Thanks for sharing, that's a cool video. I like the centering arms on their press, I'd never seen them before but thought about that same idea while working on my press. The hydraulic system are already there, it'd just be a matter of using two small cylinders on the sides with a good flow divider. It wouldn't work with my i-beam frame, but no reason not to have that on a four post press. Watching this kind of stuff makes me want to do all sorts of unnecessary things. Most of us don't work at the scale where a manipulator is necessary, but the clamping grip and controlled rotation would be great. You could get the same effect on a smaller scale press by having a rotary table set up vertically in front of it on a mill table,with stepper motors hooked up to both tables. Something like this: http://www.youtube.com/watch?v=ZHKbUYn_61o&feature=fvwrel, but you could move it back a forth from the press. Stick a scrolling four jaw chuck on there and you'd be all set. Completely unnecessary for the work most people on here do, but it would be great for a small production shop and wouldn't be too difficult to set up. I'm going to go work on my press now, instead of dreaming up more things I don't need for it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 10, 2012 Share Posted July 10, 2012 Well the larger the workpiece is and the heavier the hammer, the longer it stays at working temp---or even gets hotter! Makes it a lot easier to use some fancy setups where smaller stock would be too cold to work after you got done setting them up. Quote Link to comment Share on other sites More sharing options...
MOblacksmith0530 Posted July 12, 2012 Share Posted July 12, 2012 I have watched that video before and really enjoyed it. I think my favorite is teh last segment, I am not sure what size that hammmer is but it hits HARD! Quote Link to comment Share on other sites More sharing options...
Sam Salvati Posted July 15, 2012 Share Posted July 15, 2012 Thanks for sharing, that's a cool video. I like the centering arms on their press, I'd never seen them before but thought about that same idea while working on my press. The hydraulic system are already there, it'd just be a matter of using two small cylinders on the sides with a good flow divider. It wouldn't work with my i-beam frame, but no reason not to have that on a four post press. Watching this kind of stuff makes me want to do all sorts of unnecessary things. Most of us don't work at the scale where a manipulator is necessary, but the clamping grip and controlled rotation would be great. You could get the same effect on a smaller scale press by having a rotary table set up vertically in front of it on a mill table,with stepper motors hooked up to both tables. Something like this: [media=], but you could move it back a forth from the press. Stick a scrolling four jaw chuck on there and you'd be all set. Completely unnecessary for the work most people on here do, but it would be great for a small production shop and wouldn't be too difficult to set up. I'm going to go work on my press now, instead of dreaming up more things I don't need for it. This could be great, I bet you could get a setup like that to forge tong blanks, put an induction coil in the mix, drop a blank in then run the program using the controller to run the press also, would be a cool tool! Quote Link to comment Share on other sites More sharing options...
