Posted
Cleaned & wiped with WD40
Champion Blower & Forge Co.
Lancaster PA U.S.A.
Lancaster Geared Blower No. 40
Seems to work perfectly -
The gears inside look like new, Must have very few "miles" on it.
The pipe stuck in the snout is a 2-1/2 " 45 degree exhaust joint I had laying around, it "press-fit" inside perfectly
Getting some 1" pipe to make original style legs for it.
post-25473-0-38265000-1337439478_thumb.j
post-25473-0-58315600-1337439493_thumb.j
Posted
looks good. even with a lot of mile if you keep them oiled the gears will last with little wear. just proves alittle regular maintance goes along way.
Posted
I got that same blower. Go to the local garage door place and see if you can get the pipe from inside the springs, it is the same size as the legs on mine. (I can measure with calipers tomorrow and make sure) There is also a bracket that goes at the bottom to hold the three legs together.
Phil
