brian.pierson Posted May 8, 2012 Share Posted May 8, 2012 Dang, I will have to stop adding the "Arnold" accent in my head when I read your posts Thomas! Brian Pierson Quote Link to comment Share on other sites More sharing options...
John B Posted May 8, 2012 Share Posted May 8, 2012 So it is mounted like in picture 1 and not in picture 2? Picture 2, on the stand, is the correct way, picture 1 is upside down. Phil Should not the thrust washer/bearing be on the handle's side of the vise as the nut (static part) is to the rear? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted May 8, 2012 Share Posted May 8, 2012 Should not the thrust washer/bearing be on the handle's side of the vise as the nut (static part) is to the rear? This particular vise has a ball/cup shaped washer fitted on the screw box and on the handle and a smaller ball/cup shaped washer on the handle...or am I simply missing an additional flat thrust washer by the handle? Phil Quote Link to comment Share on other sites More sharing options...
John B Posted May 8, 2012 Share Posted May 8, 2012 So it has Phil, not apparent in the first pic you posted, but a necessary part of the vise, not hurt to point this out to anyone refurbishing or purchasing a used vise. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted May 8, 2012 Share Posted May 8, 2012 So it has Phil, not apparent in the first pic you posted, but a necessary part of the vise, not hurt to point this out to anyone refurbishing or purchasing a used vise. Not a problem. Glad I could take a better picture to show what is going on with my vise. Phil Quote Link to comment Share on other sites More sharing options...
seacoast Posted October 15, 2019 Share Posted October 15, 2019 I have a 6'' bench vise that closes and does not open. same issue discussed here. There is a bolt in the bottom of the vise that is missing. I have tried to replace it but can't find one. thank you Quote Link to comment Share on other sites More sharing options...
seacoast Posted October 15, 2019 Share Posted October 15, 2019 Can anyone tell me the name of that bolt and where to buy one? Thanks Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted October 15, 2019 Share Posted October 15, 2019 Over there at the bolt store I am sure. In case you had not thought about it, the world is a large place, and there is more than one vise maker as well, It is like asking what tire does my car need Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 15, 2019 Share Posted October 15, 2019 No need to repeat your own post if nobody responds, if you make a habit of being impatient it'll irritate admin and the curmudgeons. Is there an ID plate on it? A name? If so look them up online and contact the maker. If not, estimate the size of the bolt, hit the hardware store bolt bin and buy a couple few as close as you can estimate. Go to a REAL hardware store, not a big box, real hardware stores have a better selection and might have replacement parts that'll work on your vise. You can ask the counter guy at a real hardware store and have a chance of him/er knowing the answer or where to look it up, they have order books galore. A counter guy at a big box isn't likely to know much of anything but how to ring you up. Another pointer is providing folk enough information to be able to give you meaningful answers. Bolt, isn't much info at all but you don't know what if anything special it's called. Next time you have this kind of problem take a picture so we have a better chance. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 15, 2019 Share Posted October 15, 2019 Shoot at a good old fashioned hardware store, I'd drag in the vise and plop it on the counter and say "I need one of these!" Of course I've seen vises that used a roll pin and a washer as the "opener". Quote Link to comment Share on other sites More sharing options...
pnut Posted October 15, 2019 Share Posted October 15, 2019 41 minutes ago, ThomasPowers said: Shoot at a good old fashioned hardware store, Never shoot at a good old fashioned hardware store, because they may shoot back. Pnut Quote Link to comment Share on other sites More sharing options...
seacoast Posted October 15, 2019 Share Posted October 15, 2019 I have been to 2 or 3 real hardware stores. They could not help. I have attached pics of where the bolt goes. This thread mentioned a pivot bolt but I don't know where that goes on the vice. The only thing stamped on this vise is a large 6. No other stamping or nameplates. Thanks for the responses. Quote Link to comment Share on other sites More sharing options...
pnut Posted October 15, 2019 Share Posted October 15, 2019 Have you tried tractor supply company? They have quite a few black oxide coated bolts of larger size and different grades. They sell them by the pound Like a real hardware store. Pnut Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 16, 2019 Share Posted October 16, 2019 This thread was discussing post/leg vises, not bench vises. The pivot bolt discussed on this old thread holds the moveable jaw to the stationary one. The part you show the picture of is not a leg vise. Have you read this yet? READ THIS FIRST We still don't know where in the world you are located, hence the suggestion to edit your profile to show location. Quote Link to comment Share on other sites More sharing options...
