Gayle Brooks Posted April 4, 2012 Share Posted April 4, 2012 We have a very large door grill to do. 8' wide by 9' tall. Was going to share some progress pics of the project. I spent a good four days prototyping, making tooling, a full day on the layout, etc.1/2 x 1 bar with 5/8" square holes slit and driftedThis is the lower section of the grill. There will be another slit and drifted bar that goes on top of the rings. The rings get a bronze collar (maybe brass) on the sides covering up that seam.Cant really see much of the layout from this pic but gives a better idea of scale. This is one half and I am laying out my materials for both sides.Using clay, figured out how to do this pyramid. The challenge was two halves of 5/8" bar were poking through. We decided to forge it down to 1/2" at the end and create a shoulder on the inside and a smaller point on the outside.Figuring out the jig. My original idea was not strong enough and parts where moving. There are two bars of 5/8" square ripped down the center and opened up each being half of the diamond shape. Prototype finishedSome scroll work on top. A detail shot of the decorative piece that is inserted between the scrolls. This will also get a collar thanks! Quote Link to comment Share on other sites More sharing options...
MRobb Posted April 4, 2012 Share Posted April 4, 2012 Wow! Looks like you have your work cut out for you. It all looks great. I look forward to seeing more and the end result. Thanks for posting. Mitch Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted April 4, 2012 Share Posted April 4, 2012 Very nice looking and I really like that you showed us the jigs and the whole process, you done good!! THANKS!! Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted April 4, 2012 Share Posted April 4, 2012 WOW!! That is going to be a beauty when you get finished. I, too, am looking forward to seeing the finished product. Thanks for sharing. :) Quote Link to comment Share on other sites More sharing options...
dimenickel Posted April 4, 2012 Share Posted April 4, 2012 sweet, very cool diamond shape thanks for showing Quote Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted April 6, 2012 Share Posted April 6, 2012 Uh, large door? I would call 8'x9' a gate :blink: Beautiful work as usual, you seem to get all the choice work anybody do simple stuff there? How did you make the triangle size material, bottom die? Quote Link to comment Share on other sites More sharing options...
Ric Furrer Posted April 6, 2012 Share Posted April 6, 2012 Using clay, figured out how to do this pyramid. The challenge was two halves of 5/8" bar were poking through. We decided to forge it down to 1/2" at the end and create a shoulder on the inside and a smaller point on the outside. Figuring out the jig. My original idea was not strong enough and parts where moving. There are two bars of 5/8" square ripped down the center and opened up each being half of the diamond shape. Prototype finished Very dramatic photos...I do like black and white for iron. Suggestion....if you are splitting the 5/8 square could you cut in the stock at a severe angle to where it is still 5/8 on one side and then down to the split....leaving the 5/8 for the rivet on one element and then doing the same on the other side (but leaving the parent stock thick for the other rivet) thus having both rivets from the parent stock...no need for forging to 1/2" or any other issues....I did not explain that well. Think about the stock split....now take a 2" length of the 5/8 and set it over your drifted pass through as if it were of the same stock....measure that and try one for fit. Sorry Rory...I don't have the words to describe what I am thinking and you have a solution that looks quite stunning... Ric Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 6, 2012 Author Share Posted April 6, 2012 Thanks everyone :) Ill post more pics when something interesting happens. Right now just a lot of fitting, wire wheeling of textured material and filing...gah hate that F wordDanger Dillon: The triangle material is the 5/8" sq ripped in half on the diamond. I get some pics of that with that jig soonRic Furrer: I think I know what you are sayin. Sounds like leaving a 5/8" tip for the rivet and cut from the side and then down the center and hiding that transition in the hole. An idea Ill bring up with the boss! Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 9, 2012 Author Share Posted April 9, 2012 Took some time to prototype some decorative elements for the center This first one was 1" 1/4" sq bar at the 4" long that I started with. And final shape at the end.1 1/14" square bar at 4" long forge upset tapersForged the ends down to start the 5 pointed taper and the center is forged down to 3/4" squarefullered on the diamond. The radius needed is very close to what these dies are atNearing the final stagesdetail shot of the 5 pointed taperwhere it lives. But we decided for multiple reasons why this element just didnt fit. So I did another version that is a little smaller4" of 1" bar Left side shows the first step to help avoid the lips when forging tapers. Since I use a power hammer for this part I start a little behind the edge so mass pushes out instead of the outside collapsing and moving faster than the center.Both ends and the center forged down to 3/4"Fullered on the diamond for the radius of the scrolls And here we decided to go with the element on the right Quote Link to comment Share on other sites More sharing options...
jeremy k Posted April 9, 2012 Share Posted April 9, 2012 Rory - that element really will enhance your project. Quote Link to comment Share on other sites More sharing options...
Backwoods Blacksmith Posted April 9, 2012 Share Posted April 9, 2012 I am speechless. Great composition and effects. Quote Link to comment Share on other sites More sharing options...
ironclad Posted April 9, 2012 Share Posted April 9, 2012 thats some really great work. Quote Link to comment Share on other sites More sharing options...
beth Posted April 9, 2012 Share Posted April 9, 2012 really fabulous work rory, yes the element is gorgeous, your work continues to make my jaw drop, the designs and the craftsmanship. really strong inspiring work! thanks for all the photos :) Quote Link to comment Share on other sites More sharing options...
iron woodrow Posted April 9, 2012 Share Posted April 9, 2012 spiffing! Quote Link to comment Share on other sites More sharing options...
dan_m Posted April 11, 2012 Share Posted April 11, 2012 Rory, did you forge the rings or run them through a roller? Your work looks excellent, as usual. Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 11, 2012 Author Share Posted April 11, 2012 I forged them. Have a jig and used a couple of bending forks. Thanks! :) Quote Link to comment Share on other sites More sharing options...
Dick L. Posted April 11, 2012 Share Posted April 11, 2012 Rory, That is some very impressive design and execution to be sure ! What will hold the element in ? I'm jumping ahead trying to figure the next step :) Heavy wire wrap ? Collar ? Weld ? Anxiously waiting for more ! Dick Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 12, 2012 Author Share Posted April 12, 2012 all in time, sir...All in time (probably a weld on the back then collared) Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 13, 2012 Author Share Posted April 13, 2012 Video of making the scrolls for the top Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 13, 2012 Share Posted April 13, 2012 Rory: I'm in awe, from concept to design to forming to assembly it's all masterful and beautiful. A skill level to aspire too. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 18, 2012 Author Share Posted April 18, 2012 Thanks Frosty! :) Some video of how I did the center diamonds. Since they are in halves this might make a little more sense http://youtu.be/HiBVkKHErjwTwisting 3 flats around slit and drifted hole. The tool in the vise helps control where the twist starts as well as keep it off the vise since its a great heat sinkThe long skinny part on the center sits ontop of the jaws. Made a handle since it was getting warm. Ended up super quenching the end to help with a few more twists. If I do this again I am making this tool a bit more aggressiveJig for the diamond halvesalmost 80 pieces forged for this whole thing. Have materials for both doors here. Quote Link to comment Share on other sites More sharing options...
TomN Posted April 18, 2012 Share Posted April 18, 2012 Marvelous stuff. This is the kind of thing I dream about doing in the future! Really inspirational and its helpful to see how execute your design elements, so thanks for putting in all the photo's and the video's. I shall keep watching this as it progresses! Good luck with the rest of it. Quote Link to comment Share on other sites More sharing options...
Chad J Posted April 19, 2012 Share Posted April 19, 2012 Good work.... Or maybe Great work... No. That is AWESOME WORK! Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted April 20, 2012 Author Share Posted April 20, 2012 Thanks for such nice compliments! Feel free to ask any questions or if I did not explain something. I like these kind of topics since it shows how much work goes into a piece. With the amount of sharing, ideas and content, I am wanting to see just how they did it. Which only builds on the life of the project instead of its final resting place. I had a fireplace door that got put on hold while we were waiting for some details. The project is now live and this grill will be put on hold for about a week. The last thing I did was start on the mounting plates that mount to the face of the door. Straight forward plate with a grooved line. A video of our tooling under the hammer as well. Mark the top radius cold and then I do it hot by hand Groovin http://youtu.be/pi_6r2LL23s Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted April 20, 2012 Share Posted April 20, 2012 WOW!! Groovy man! Sorry! It was just laying there. How could I resist? Quote Link to comment Share on other sites More sharing options...
