Tooneyman Posted March 8, 2012 Share Posted March 8, 2012 Will be MIG welding a 1" dia. steel pipe to a thin 1/8" perpendicular steel base plate soon and need advice on how to prevent the pipe from getting out of plumb if the welding causes some warpage of the base plate. Welding process and clamping of parts to prevent or minimize warpage from welding will be greatly appreciated. Been MIG welding for a couple of months, but still a "newbie" at it. Any advice will be appreciated. Quote Link to comment Share on other sites More sharing options...
r smith Posted March 8, 2012 Share Posted March 8, 2012 Your baseplate will warp. Tack it in one spot and re-adjust for square, when you like it tack it on the opposite side from first tack. Then do the sides, Always little tacks and always checking after each one. Quote Link to comment Share on other sites More sharing options...
mike-hr Posted March 8, 2012 Share Posted March 8, 2012 That's a pretty thin baseplate. I'd do some test pieces before the real one. I'd also consider drilling a through hole in the base, countersinking and chamfering both chunks from the underside, and welding it from the underside. the warp will work for you, setting the edges on the ground, slightly raising the center when it's finished. Quote Link to comment Share on other sites More sharing options...
cvmikeray Posted March 8, 2012 Share Posted March 8, 2012 Start your welds on the thicker metal and flow out onto the plate makin sure to not linger to long on the plate. Also work opposite sides if square and skip weld a few places if round and then fill in is how I would go at it. I'm no expert on the subject either. Also a rotating surface will help as well so you can turn the work and not your self. Tack welds should keep your plumb in place . Also make sure the surface is good and clean. Quote Link to comment Share on other sites More sharing options...
bajajoaquin Posted March 8, 2012 Share Posted March 8, 2012 That's a pretty thin baseplate. I'd do some test pieces before the real one. I'd also consider drilling a through hole in the base, countersinking and chamfering both chunks from the underside, and welding it from the underside. the warp will work for you, setting the edges on the ground, slightly raising the center when it's finished. That's a really good idea. Talk about coming at the problem from a different angle! Quote Link to comment Share on other sites More sharing options...
knots Posted March 8, 2012 Share Posted March 8, 2012 In the past, when it really matterd (which is not to often) I have drilled a hole in the base and used all-thread to temporarily clamp the pipe to the base. If you get a good true to square cut on the pipe, the pipe will be held in place and you should be good able to get a good square weld. If the cut is not exactly square use shims to square the assembly up, torque it down and weld away. Quote Link to comment Share on other sites More sharing options...
Spears Posted March 8, 2012 Share Posted March 8, 2012 Do what r smith said but with the addition of a small shim say .015-.020" thick same diameter as the pipe. The shim is placed right where the pipe will be and clamped between a thick flat plate to create a hump and balance out the warp which it will "draw" up no matter what. Clamp around the shim as much as possible before any tacking and jump around with plenty of tacks before running a bead. Leave all clamps on at least 10-15 seconds after final weld. If it still draws up quite a bit, use a thicker shim next time. It may never go perfect but an 1/8" plate can be bent back pretty easy with a hammer. Good luck with your project. Spears. Quote Link to comment Share on other sites More sharing options...
