keithh999 Posted February 16, 2012 Share Posted February 16, 2012 just found this pdf that will help with lengths of material for scrolls and has several sizes of scrolls drawn out that you can use for a template or a jig.http://www.metalcraftusa.com/documents/mk122223scrollbenderoutlines.pdf hoping this should help those of us who have an issue with scrolls Keith Quote Link to comment Share on other sites More sharing options...
Guest baddog Posted February 16, 2012 Share Posted February 16, 2012 Very nice. That will come in handy! Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted February 18, 2012 Share Posted February 18, 2012 There has probably not been much of a response to the diagram, because nobody wants to play the "devil's advocate." One must realize that the provided informaion is designed for 1/8" or 3/32" thick stock to be bent cold. That is why they give advice about "spring back." If scrolls are made hot on a form, there is no spring back. Furthermore, if the stock is thicker than 1/8", that changes the length of material needed. In my opinion, the scrolls, as drawn, are not very good looking, especially the central portion, in which the negative space is too open. If one is seeking exponential growth from the center, it is not well done in the drawings. I'm talking about Mother Nature's scrolls, such as a snail shell or chambered nautilus shell. I say this realizing that good scrolls may have different radii. Quote Link to comment Share on other sites More sharing options...
keithh999 Posted February 18, 2012 Author Share Posted February 18, 2012 nothing saying you cant improvise ,adapt and overcome the templates deficiencies....its just a baseline to help get you in the ballpark. Quote Link to comment Share on other sites More sharing options...
