Posted
what I am using is a metal 2x4 & larger size's sheet metal wall stud's there easy to find @ any construction site
a friend of mine made a 20' steel rack with them he has one stock size per slot nice & organized
& hanging from the rafters outa the way above my short pieces is my 20' bars - will be building more 20' bar storage
on the soon :D COOL got the pic thing figured
Posted
Hope you are using PLENTY of VENTALATION!!! That's the stuff you die from. Granted, you are not doing that much welding ont he galvy stuff but metal fume fever is an acculative thing, each dose builds on the last dose. Your body can't get rid of the fumes.....other than that your storage idea looks great!
Posted
Good use ho humm material. I really need to do something similar rather than a nasty pile under the table, I'll get a round tuitt some day..... :rolleyes: ...............The uploading of pix has improved, thanks guys!
  • 2 years later...
Posted
Using various sizes and lengths of PVC or other piping works well also.You can either stack them or align one on top of each other on a 45degree angle along a wall or other out of the way area and slide your pieces into them.
