John B Posted January 18, 2012 Share Posted January 18, 2012 Farmer Phil asked some questions about how I had positioned a rose in a heart in a previous post, so thought it would be an idea to see what others have done and where they have used theirs. This is what I turned mine into, A Candleholder for a 3"diameter church candle. and some details of the assembly and with its slippers fitted so it can rest easy and non scratch Thanks to Mr Brazeall for the idea, and also to the moderators for getting the pic fixing attachment sorted. Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted January 18, 2012 Share Posted January 18, 2012 John, That looks great. I really appreciate your showing how you attached the heart. I have piles of shoes just waiting. Also thanks to Brian Brazeal for getting the ball rolling. Mark <>< Quote Link to comment Share on other sites More sharing options...
Phil Dwyer Posted January 19, 2012 Share Posted January 19, 2012 That sure looks sweet John. Did you punch or drill the mortise in the V of the heart? If you punched it, how did you go about it? Also, how tricky was it riveting the tenon? Was the heart already completely shaped when both the mortise was made and the tenon riveted? I see the shoulders of the tenon set down in and take the shape of the V of the heart, which I presume holds the post fast so it won't pivot. Did you just seat it hot such that it took the shape of the V? That is a great ensemble! You got three of the greatest and most ephemeral archetypes in one piece--a heart, a rose and a flame--rendered in one of the most solid and physical of all Earthly substances--iron/steel! Volumes of esoterica could be written about that, if they haven't been already! Quote Link to comment Share on other sites More sharing options...
John B Posted January 19, 2012 Author Share Posted January 19, 2012 Thanks Phil, This piece sort of evolved from a piece of 5/8"diameter bar using Mr Brazealls suggestions for making a heart, I then had demoe'd a copper rose which was lying around doing nothing so I thought it would look good in the heart frame, Options available were to weld it in place, or rivet it on front/back/centre Decided I wanted it to be in the corner on the centreline of the piece for balance. So I made a short stem that would have a tenon on one end, and an eye on the other for the rose to fit to and it should place the rose as a central feature in the heart. This also meant I could remove and refit the rose as necessary. I drilled and countersunk a hole in the heart's corner as I liked the crisp line appearance that would have been difficult to maintain if I had punched it, and dressed of the burrs produced on the inside corner with a small threesquare file. I then made the stem, eye end first, then roughed the tenon at the length I wanted, and whilst the tenon end still hot, seated it into the hole from the inside, usint the heart as a monkey tool to set down the tenon's shoulder, this shoulder also stops the stem being susceptible to turning or coming loose when rivetted in situ, When I was happy with the fit, I heated it again and rivetted it into position, then dressed down the rivetted size to blend in. I managed to hold the stem in the leg vice whilst rivetting and monkeying. Any final alignment can be done with the torch and local heat. The fitting to the candleholder is another story. Quote Link to comment Share on other sites More sharing options...
Greenbeast Posted January 19, 2012 Share Posted January 19, 2012 Thanks for the description! Quote Link to comment Share on other sites More sharing options...
beth Posted January 19, 2012 Share Posted January 19, 2012 thats lovely john, very cool way of attaching the rose, it looks great. your description detailed and easy to understand too as usual, thats a good way to show a rose, ie not in the Vase scenario... for mrs john for valentines day??? :) Quote Link to comment Share on other sites More sharing options...
Don A Posted January 19, 2012 Share Posted January 19, 2012 These are forged from W-1 drill rod and water quenched... Firesteels for striking flint and making fire. Not a documneted style, but too cool not to make. Quote Link to comment Share on other sites More sharing options...
