Iron Striker Posted December 14, 2011 Posted December 14, 2011 I see posts containing references to the types of steel being used for different applications. Does anyone know of a book or web site that a beginner like me could use to better select the type of steel required? Something written in "laymans" terms. Thanks, Jamie Quote
Rich Hale Posted December 14, 2011 Posted December 14, 2011 Welcome to the site Jamie. It might help a little with your question if you let us know wot you are interested in making. By that I mean if you are making blades we can head you in one direction. scrolls animal heads etc another, Tools lsuch as punches, hammers or chisels another. Fill in some blanks and we can likely fill in some answers. And more than likely can provide some sources near you. Quote
ThomasPowers Posted December 14, 2011 Posted December 14, 2011 Machinerys Handbook has a fairly concise listing of steel types and suggested uses at least as of the 23rd edition that I have. The ASM handbooks, now close to that proverbial 5' shelf of books, has a more in depth going over but tends to be more esoteric and quite expensive. (I pick up stray volumes whenever I run across them cheap; the heat treating one is my favorite) Quote
pete46 Posted December 14, 2011 Posted December 14, 2011 For junkyard or found steel what was its old job ie...leaf spring, might b med carbon, railing= mild steel,chisel= tool steel, hammer head= cast steel or D2 etc. Its guess work but it'll get you in the ball park. Hope this helps. Quote
MattBower Posted December 14, 2011 Posted December 14, 2011 (edited) No, I don't know of a single, concise resource that contains what you're looking for, although Machinery's Handbook does have a table that suggests steels (often expensive ones) for various applications. That will get you in the ballpark, as will the various junkyard steel charts. But the first step is to start becoming familiar with steel terminology, the basic properties of different types of steel, and then the more common alloys and their specific properties and common uses.Mod note: Link removed at the request of Anvilfire. Edited August 18, 2012 by Glenn external link removed due to request from that site's administrator Quote
ThomasPowers Posted December 14, 2011 Posted December 14, 2011 note that EVERY junkyard steel list I have seen has had some major problems based on the fact that suggested materials are often not used in favor of *cheaper* materials---for example their are few if any jackhammer bits made from S7, most are just a plain middle carbon steel. Another one I have personally run into is a low alloy strain hardened leaf spring that could not be quenched hardened! (of course that's 1 in 30+ years of smithing...) Quote
Francis Trez Cole Posted December 14, 2011 Posted December 14, 2011 I found this site very easy to use just type in the steel you want to use and the description is pretty simplehttp://www.suppliersonline.com/Research/Property/metals/25.asp Quote
Iron Striker Posted December 14, 2011 Author Posted December 14, 2011 Thanks for all the replys. I am mainly interested in knife steels. There seems to be nothing in the local book stores on the subject. A trip to the library would probably help. So much to learn! Thanks again. Jamie Quote
MattBower Posted December 14, 2011 Posted December 14, 2011 note that EVERY junkyard steel list I have seen has had some major problems based on the fact that suggested materials are often not used in favor of *cheaper* materials---for example their are few if any jackhammer bits made from S7, most are just a plain middle carbon steel. Another one I have personally run into is a low alloy strain hardened leaf spring that could not be quenched hardened! (of course that's 1 in 30+ years of smithing...) I agree completely, Thomas, and that's a worthwhile point to make for the sake of any casual Internet surfers who might happen upon this thread, read it less-than-carefully, and draw the wrong conclusions. But to be clear, I think the original poster's question was not, "where can I find junkyard steel of type X?" Junkyard steel charts are very problematic for answering that sort of question. However, I believe his question was, "where can I find a reference that tells me what kind of steel would be good for making item Y?" And I think the junkyard steel charts would actually do a fair (if somewhat limited) job of that, although the steels they list for many applications are often much higher-end than what industry typically uses. Quote
ThomasPowers Posted December 14, 2011 Posted December 14, 2011 As for knife steels I would think that "The Complete Bladesmith, The Master Bladesmith and the Pattern Welded Blade" all by James Hrisoulas would have quite enough info on suggested steels and how they need to be forged! I would start with the first one; still time for it to be a Christmas present if you expedite shipping... Quote
Iron Striker Posted December 14, 2011 Author Posted December 14, 2011 Thomas, I will check out those books. I have to remind myself that when talking on a forum it pays to be specific. Sorry for the broad question. Thanks again to all of you! Jamie Quote
MattBower Posted December 14, 2011 Posted December 14, 2011 Ah, I didn't see your added comment about blades. That does indeed make a difference. If you're interested in forging blades, the list gets even smaller -- although it's still pretty lengthy. Dr. Hrisoulas' books are excellent resources. Quote
Iron Striker Posted December 14, 2011 Author Posted December 14, 2011 Ok here is another question. Do Dr. Hrisoulas books cover preforms for blade forging? Quote
ThomasPowers Posted December 14, 2011 Posted December 14, 2011 ILL them at your local public library and see if they fit your needs/preconceptions! Quote
Glenn Posted December 15, 2011 Posted December 15, 2011 BP0002 Junk Yard and Rail Road Steels BP0002 - Junk Yard and Rail Road Steels Quote
Steve Sells Posted December 15, 2011 Posted December 15, 2011 Many of the common questions has answers at the top of the section it applies to. For example copper questions would be in the non ferrous metals section. Not everything is in the general smithing section. Since you asked about blade steels, look at the knife sticky's, this one: http://www.iforgeiro...choosing-steel/ has the answers to some of the questions you asked. Quote
Woody Posted December 15, 2011 Posted December 15, 2011 I have a fairly comprehensive list of the composition of various junkyard steels as well as a list of some of the more common blade steels along with heat treating information that I have gleened from various websites, ABANA publications and other reference materials such as Machinery's Handbook. Message me with your email address and I will send you a copy. It is about 20 pages in MS Word format. Quote
