Ric Furrer Posted October 31, 2011 Share Posted October 31, 2011 Hello All, If you happen to have a self contained hammer I have a request. Set you bathroom scale under the ram when at rest (I used a small jack, just past the die, to lift and set it back on the scale). My 3B Nazel has a weight of 230 pounds for ram and die. This seems light to me, but you get what you get. What do others have for a ram weight on their hammers? Ric Quote Link to comment Share on other sites More sharing options...
basher Posted October 31, 2011 Share Posted October 31, 2011 ric is it not likely that there is some friction resulting from the ram touching the bore . try tapping the hammer with a great big hide mallet and see if you can put some weight on . Quote Link to comment Share on other sites More sharing options...
nonjic Posted October 31, 2011 Share Posted October 31, 2011 I have weighed a few Massey 'Clear Space' rams, and a few smaller Alldays & Onions ones. They have all been scarily close to catalogue specs. (I have weighed the odd large anvil block and they have been within a few % aswell!) It could be your ram has had a broken dovetail in the past and had a chunk machined off the end? or as Owen says it might be a bit sticky in the bore and box, you could try the experiment again when the hammer is nice-n-hot-n-loose to see if it makes a difference! Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 31, 2011 Share Posted October 31, 2011 That's right on the spec for an older Nazel. They seem to have increased the weight over the years. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted October 31, 2011 Share Posted October 31, 2011 My 3B is 285 lbs with the die. Quote Link to comment Share on other sites More sharing options...
kerrystagmer Posted November 1, 2011 Share Posted November 1, 2011 I'll check the 2b but the 4b ram isnt here right now. I can check it when we get the parts back in house. Quote Link to comment Share on other sites More sharing options...
Ric Furrer Posted November 1, 2011 Author Share Posted November 1, 2011 1365 is my hammer number I recall. It has a gross weight of 13,300..heavy for the nazel...so I do not know. I do not believe that the ram is stuck in any way..the weight is accurate. Ric Quote Link to comment Share on other sites More sharing options...
monstermetal Posted November 10, 2011 Share Posted November 10, 2011 My 3b is 225 with die and the 4b 340 with die both weighted out of the hammer Quote Link to comment Share on other sites More sharing options...
Phillip Patton Posted November 10, 2011 Share Posted November 10, 2011 My 75 pound Bradley has a 99 pound ram. :) Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted November 11, 2011 Share Posted November 11, 2011 Ok, Phillip broke the mechanical hammer ice. My 85# Kane and Roach mechanical has an actual ram weight of 95#. On a related note, I don't recommend using your wife's bathroom scale unless she is more tolerant of cracked dial covers and oil drips than my wife is. ;) Quote Link to comment Share on other sites More sharing options...
brian robertson Posted November 11, 2011 Share Posted November 11, 2011 Just tell her, she's perfect the way she is and doesn't need that scale anyway... Quote Link to comment Share on other sites More sharing options...
Ric Furrer Posted November 11, 2011 Author Share Posted November 11, 2011 Ok, Phillip broke the mechanical hammer ice. My 85# Kane and Roach mechanical has an actual ram weight of 95#. On a related note, I don't recommend using your wife's bathroom scale unless she is more tolerant of cracked dial covers and oil drips than my wife is. that sounds like operator error more so than general concept. I am a blacksmith...I believe that proves my wife is tolerant......its when the stainless mixing pots end up filled with wax and boiled linseed oil that she gets a bit testy. Ric Quote Link to comment Share on other sites More sharing options...
