ambos Posted October 21, 2011 Share Posted October 21, 2011 I'm looking for a replacement spring for the bypass valve on my 2B Nazel hammer. Does anyone know the size or correct description, and also where I might order one from? The spring I have does not seem to have enough return (it is too stiff and slow to react) to raise the hammer properly - a softer spring would react faster and allow more air into the chamber to raise the hammer. Quote Link to comment Share on other sites More sharing options...
Fosterob Posted October 21, 2011 Share Posted October 21, 2011 If your hammer is worn out to the point of not working properly then fix the problem instead of trying to reengineer it. Can you give more details of what is wrong with it? Also you should post your location under your profile. Rob Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 21, 2011 Share Posted October 21, 2011 Can you pull the stem down by hand? If I remember, on the 2-B, you should be just able to pull it down. Quote Link to comment Share on other sites More sharing options...
