Dillon Sculpture Posted September 29, 2011 Share Posted September 29, 2011 Big stuff will beat the xxxx out of you if your not carful, how bout a handle with a built in isolator. 1" pipe tee handle, 1/2"x 1" bar twisted around a piece of solid 1" round weld it up. Need a bigger forge? The 6 burner NC bolts together, just add bricks! Can't get to your treadle on the hammer? Here is a extension made from 1" angle and a piece of pipe, it will also slide around to any position. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted September 29, 2011 Share Posted September 29, 2011 Good ideas, Michael. Thanks for sharing them. I can use a couple of them, now. :) Quote Link to comment Share on other sites More sharing options...
HWHII Posted September 30, 2011 Share Posted September 30, 2011 I really like the treadle extension. Going to have to make a couple of those. Thanks! Quote Link to comment Share on other sites More sharing options...
macbruce Posted September 30, 2011 Share Posted September 30, 2011 This contraption works well to prevent getting waged by the big dog as well, works like a charm for towing vehicles too...... Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 30, 2011 Share Posted September 30, 2011 I've seen sections of large diameter cable welded in to isolate as well. That treadle extension is the cat's meow! No more trying to work a piece in warrior one position... Quote Link to comment Share on other sites More sharing options...
