Rangerdave Posted September 27, 2011 Share Posted September 27, 2011 My first attempt at tongs. Functional but not very pretty. I will be trying again once I get my forge built. Quote Link to comment Share on other sites More sharing options...
Rangerdave Posted September 27, 2011 Author Share Posted September 27, 2011 wow the pictures actually worked. I figured it would be a hassle. Very good instruction as even I could follow it successfully. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 27, 2011 Share Posted September 27, 2011 Not bad! Leaving the reins stock thickness uses a lot more material, but does simplify the process considerably. Phil Quote Link to comment Share on other sites More sharing options...
Rangerdave Posted September 27, 2011 Author Share Posted September 27, 2011 I actually like the hex and size so I left it. I should have drawn it out as my bro in law has a air hammer. Would have made process a lot easier than by hand. And it will be quite some time before I have the $ or knowledge to need an air hammer. But it works so I will work on the looks when I do my next pair. RD Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 27, 2011 Share Posted September 27, 2011 My first pair of tongs broke after a few days of use...easy bar to step over. I have a couple pair of tongs that I made and use. It does get easier. If you want a wide grip you can always make it oval in cross section (on future tongs), but there is a point when you need to use medium carbon steel if you make the reins light and springy. I would not rework these until you have made other pairs, or they have a specific problem. Phil Quote Link to comment Share on other sites More sharing options...
freeman Posted September 27, 2011 Share Posted September 27, 2011 Congratulations on your successful venture into toolsmithing! They won't win any beauty contests, but then again either would any of the sets of tongs I've made. If they're functional (and they certainly look functional) use then until they break or you make a better pair. There's something profoundly satisfying with bootstrapping your own tooling! Quote Link to comment Share on other sites More sharing options...
metalmangeler Posted September 28, 2011 Share Posted September 28, 2011 They look pretty good for a first pair to me. You will no doubt get better as you go. Quote Link to comment Share on other sites More sharing options...
Pault17 Posted September 28, 2011 Share Posted September 28, 2011 Great first shot Dave. if they hold metal securely, they work. My very first pair was modeled after Glen's Son's blueprint. simple, straight forward and (in my case) BUGLY. but they hold very solidly and always have. I still use them for certain applications keep it up Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted September 28, 2011 Share Posted September 28, 2011 Good job, thank you for sharing. Quote Link to comment Share on other sites More sharing options...
double_edge2 Posted October 2, 2011 Share Posted October 2, 2011 Good set for first time..... Keep it up Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 2, 2011 Share Posted October 2, 2011 I don't see anything wrong with those Dave, not a thing. Purty is for decorative stuff, not things you're poking into the fire over and over, robust is far more important. Darned things sure look better than my first pair. Did I understand you correctly, that you made these from hex stock? If so it's almost undoubtedly high carbon and is going to need you to be careful using them. Do NOT quench them if they reach red heat, quench them often so they don't each red. Being tool steel quenching from red or hotter can make them brittle and tongs take a lot of stress around the rivet. The rivet and rivet hole have a LOT of leverage working against them, you're hand on the long reign and another 1 1/2" - 2" on the bit end, that make a compound lever. Meaning the last thing you want is brittleness anywhere near the pivot. You get a hearty Atta boy John. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
Rangerdave Posted October 4, 2011 Author Share Posted October 4, 2011 Thanks Frosty. I don't know what kind of metal they are. I will take your advise and make sure they don't get to hot. Quote Link to comment Share on other sites More sharing options...
