SReynolds Posted September 27, 2011 Share Posted September 27, 2011 I have had some small fires in my rebuilt Champion forge. It is of a steel pan with cast iron air pipe. I have installed a new floor in the pan of 1/4" steel plate. Upon building larger fires, as if I were to use it, the forge emits popping noises, like a cast iron engine block. I'm concerned that it will crack. It is old and has probably been used many times, but this worries me. ................should I have left the attatching hardware loose? Do these steel forges with cast iron air pipes normally make sounds like this? I can't imagine what will happen when I begin to sprinkle water on the hot coals! This is my first portable unit as my other forge is fire brick/stone/morter etc. with a metal plate in the bottom. It makes no noise. Link to comment Share on other sites More sharing options...
jeremy k Posted September 27, 2011 Share Posted September 27, 2011 My guess would be, the noises are from expansion during the heating process. I would make sure that the holes you attached the new pan with are oversized to allow for movement ( assuming you bolted v.s welding ). It's really hard to tell without a few clean, clear pictures of how you modified the forge. I myself wet the coal, vs, adding water to a hot forge. I start the forge with dry coal, while the fire is starting I water down the coal in the rest of the forge, this way the water is never added directly tot he hot forge after the forge is heated up ( just my way ). This is for starters, from info given. Link to comment Share on other sites More sharing options...
pkrankow Posted September 27, 2011 Share Posted September 27, 2011 Sheet metal and cast iron forges are typically clayed on the inside to protect the metal. Phil Link to comment Share on other sites More sharing options...
glen56 Posted September 28, 2011 Share Posted September 28, 2011 yep listen to phil mate ,my very 1st forge gave a resounding crack when i built the fire directly on the cast ,welded it up again but a sad thing ,i just use dirt in mine ,cheers ,glen Link to comment Share on other sites More sharing options...
Please sign in to comment
