Luke March Posted September 16, 2011 Share Posted September 16, 2011 So, I am finally going to build myself a belt grinder. Since I am rather new to the world of belt grinders, I have a question for those of you with more experience. I have heard/read more than once that good quality belts are important... So where do you get your belt grinder belts, or what brands do you use? Link to comment Share on other sites More sharing options...
Steve Sells Posted September 17, 2011 Share Posted September 17, 2011 it all depends on what you want to grind, If blades, look in the blade section, try this thread for talks about grit and brands for knife work... http://www.iforgeiro...chat-june-1909/ Link to comment Share on other sites More sharing options...
Dodge Posted September 17, 2011 Share Posted September 17, 2011 Regardless of what I'm grinding, I like these guys: http://www.knifeandgun.com/ Can't go wrong with 3M or Norton... Link to comment Share on other sites More sharing options...
Steve Sells Posted September 19, 2011 Share Posted September 19, 2011 Stainless needs a different medium than softer metals. So does wood and brass for handles... Link to comment Share on other sites More sharing options...
pkrankow Posted September 19, 2011 Share Posted September 19, 2011 I've been using big box belts, whatever they have, and have also used better belts. Night and day difference. When I plan on doing some grinding I will order some good belts. For tool sharpening and whatnot I use the cheap ones I get locally. The surface finish is the same, but the longevity and speed of stock removal is very different. Phil Link to comment Share on other sites More sharing options...
EGreen Posted June 8, 2012 Share Posted June 8, 2012 used to be a company called Industrial Abrasives. good people, buy a dozen get a free dozen. Link to comment Share on other sites More sharing options...
Rich Hale Posted June 9, 2012 Share Posted June 9, 2012 I did a bp on this years back with all of the belts I use for knife making, I use the same belts for stainless steel and high carbon steel. The bp is number o235 you can find it in the pages section. Since I made that bp I have changed the coarse belts listed to norton blaze belts. I still use trizac belts for finer but they make a lrixac with a serrated face, I do not like that belt. I prefer the p;lain trizac. Link to comment Share on other sites More sharing options...
Robert Yates Posted June 9, 2012 Share Posted June 9, 2012 I'll second Industrial Abrasives , 3M or Norton, http://www.progresstool.com/cat_belts.cfm this is my go to guys for supplies . Sam Link to comment Share on other sites More sharing options...
petere76 Posted June 9, 2012 Share Posted June 9, 2012 Google-POPS Knife supply. Big selection of all your needs for knife production and the prices are very reasonable. If you call when they are open (1600 -2000 M-F EST) the gentleman is very knowledgable and will help you any way he can. Good luck with your project. Peter Link to comment Share on other sites More sharing options...
ironsmith Posted June 10, 2012 Share Posted June 10, 2012 I second POP knife supply, I went by his place and he treated me right. and is very knowledgeable on his merchandise... Link to comment Share on other sites More sharing options...
gearhartironwerks Posted June 10, 2012 Share Posted June 10, 2012 How about : usaknifemaker.com JE Link to comment Share on other sites More sharing options...
Luke March Posted June 12, 2012 Author Share Posted June 12, 2012 Wow, this thread came back to life. I started with some belts from usaknifemaker; they seemed to work pretty well, but for a college student, $15 seems kinda high for a single belt. Right now I'm trying out some belts from this local place: http://www.fintechabrasives.com/sanding-belts They actually make sanding belts and drums, and it's really close to where I live; I don't have to pay any shipping costs. I can't say how well they hold up, as I have not used them a whole lot yet, and I also do not have a very good point of comparison with other belts; but being able to afford multiple grits allows me to do some things I couldn't before... considering that I can get a pack of 6 2x72" belts for $12. By the way, they have a really good deal on sanding sheets; $20 for 10 lb of sandpaper. It's all cloth backed; I think most of it is cutoffs from when they make the 6" or 8" wide sanding belts. Link to comment Share on other sites More sharing options...
petere76 Posted June 12, 2012 Share Posted June 12, 2012 Luke, Just a suggestion. Dont spend the money on the high end belts if you are just starting out. You will go through a few in the learning process. 3m brand, alu oxide at $4.50 or less is a good place to start. Get a good hogging belt like a 50 grit for the rough stuff. a few 120 grit for the mid range and a 220 for a finish. These will get you started. If you want the ultimate mirror finish you need to go higher and thats one place that the pros spend the money on the high end belts. Good luck. Peter Link to comment Share on other sites More sharing options...
bigfootnampa Posted June 18, 2012 Share Posted June 18, 2012 I ordered some of those belts from Finntech Luke. Thanks for sharing them! Their shipping is quite a bargain at $8.45 for up to $250 orders and FREE for larger orders! I like the looks of the company and will let you all know how I like their belts. I had rather change belts oftener than to pay more and try to grind with them longer than I should. BTW I recently received a new 2X72 grinder from pheer1 on ebay and I am pleased with it. I think I got a very good bargain on this grinder. Variable speed and 10" contact wheel for less than $1,000 including shipping! I hadn't the time or knowledge to build my own and this one seems very well made. Link to comment Share on other sites More sharing options...
Walowan Posted September 18, 2012 Share Posted September 18, 2012 klingspor's is a good source for cheap sanding supplies Link to comment Share on other sites More sharing options...
nuge Posted September 19, 2012 Share Posted September 19, 2012 I like pops knife supply.. Best prices I've found, never had a backorder, great manners on the phone. Fast shipping the biggest plus. Love the 3M "gold belt". Link to comment Share on other sites More sharing options...
hamer built Posted October 26, 2012 Share Posted October 26, 2012 go to supergrit abrasives! jim Link to comment Share on other sites More sharing options...
windancer Posted October 27, 2012 Share Posted October 27, 2012 Supergrit Abrasives- Norton Blaze Orange belts Link to comment Share on other sites More sharing options...
Please sign in to comment
