Ironswine Posted August 24, 2011 Posted August 24, 2011 The only steel I have on-hand right now is some scrap handle bars from a makeshift motorcycle. It's pretty thick pipe, about 1/8 thick with a diameter of 3/4s of an inch. Is this useful for anything? I have about a foot of it. Quote
John B Posted August 24, 2011 Posted August 24, 2011 Hi I, Pipe is ideal for making candlesticks, candle holders etc by swaging them in and flaring them at appropriate positions You can flatten it, forge it into squares or rounds, twist these sections and generally play around to your hearts content, A couple of Safety points, Don't use plated tubes, they can give off toxic fatal fumes, and block off the end you are going to grip, you may also need tongs to grip the stock as the heat transfers up the pipe when it is being heated, and if you cool it, you will get a jet of boiling steam coming out of the end to scald you. Take care and have fun Quote
Marksnagel Posted August 24, 2011 Posted August 24, 2011 Ironswine, I have a pretty good BP on how to make some really nice candlestick holders from CurlyGeorge. If he doesn't answer this post, let me know and I'll email you what he sent me. Mark Quote
Ironswine Posted August 24, 2011 Author Posted August 24, 2011 Thanks you guys. Is there any way to identify galvanized/plated steel? I found another pipe from an old air gun that I'm pretty sure is just painted black, and the other has been welded on before. Quote
Bentiron1946 Posted August 24, 2011 Posted August 24, 2011 Scratch the barrel of the old air gun as some of them were made of thick wall brass and were brazed not welded. Quote
JimsShip Posted August 24, 2011 Posted August 24, 2011 Ironswine, I have a pretty good BP on how to make some really nice candlestick holders from CurlyGeorge. If he doesn't answer this post, let me know and I'll email you what he sent me. Mark Mark- If CurlyGeorge doesn't post, could you send them to me? I'd like to see them as well. Quote
IRON FIST RICH Posted August 25, 2011 Posted August 25, 2011 Pipe also makes a good candle snuffer RICH Quote
ThomasPowers Posted August 25, 2011 Posted August 25, 2011 Here in the land of the "Red or Green" (official state question!) we make chile peppers from pipe. Taper one end and then round slightly and use a fuller to neck in the top a bit above the start of the taper. I fuller enough that you can forge the fullered section down into the stem Quote
Steve Sells Posted August 25, 2011 Posted August 25, 2011 Flowers are nice, I like to make Lilly's from pipe, and Thomas: Red of course :D Quote
