bajajoaquin Posted August 22, 2011 Share Posted August 22, 2011 I have a cast iron rivet forge I picked up at a show a little while back, and I was thinking of getting it in firing shape. There's nothing written on it that says, "line with clay" like I saw on another post here. But was this something that is assumed with these things, or can I just put on a firebowl and tueyre and make a fire? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 22, 2011 Share Posted August 22, 2011 If it does not have a thick, heavy, separate casting for the fire pot, clay it. 3 parts sand 1 part Portland (the active ingredient in Cement) (optional) 1/2 part clay (such as yard subsoil or generic non-clumping kitty litter) Mix dry, then add water while mixing. It should have just enough water to stick together, it should break instead of squishing when you pinch a packed handful. Pack it in place forming a bowl around the tue, then take it level to the side. if you shop for broken bags at the big box then you may be done for $2. Phil Quote Link to comment Share on other sites More sharing options...
