Scrap/junk yard motors
Firstly I come from(and now live in) a part of the world that uses 240V domestically and 380V industrially, by and large.
I have no knowledge about 110V, this may or may not aply to 110V motors.
A lot of guys see electrical motors in Scrap/junk yards but are weary of buying them in case they don't work!
Well you can "test" them and be 95% sure with a multi-tester that can be bought cheaply .
As shown set your tester to check continuity as indicated in the first picture.
now test that each of the 3 points as indicated with the blue ferrules(in a line) with each of the others - they must each make a circut.
Now check that they do not make a circut with the earth as indicated by the blue ferrule that does not line up with the other three.
Please check that the motor turns freely and if it does you can be 95% sure that this motor will work! B)
post-13949-0-55542200-1312805635_thumb.j post-13949-0-81417800-1312805598_thumb.j
  • 1 month later...
