devo Posted May 1, 2011 Share Posted May 1, 2011 I was given an anvil recently that I'm very excited about; the anvil I have been using is borrowed and much smaller. There's a section of face on the new one that is missing, and it's pretty beat up, but I'm happy to have it. It was found half buried at a facility that opened around 1905. What can you guys tell me about this thing (age, etc)? Can I build up the missing face section and grind it flat? Here's some photos: Thanks! devo Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted May 1, 2011 Share Posted May 1, 2011 Wow lucky you. That is a great gift. Use it and enjoy it. Do you know what is weighs? Mark<>< Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 1, 2011 Share Posted May 1, 2011 Howdy from East TEXAS!! and welcome to IFI! If you can make out the serial number, left side of the front foot, then we can tell you how old. (I tried but could make it out) No matter the age, it is still a good tool, and the price is the kind I like... FREE!! Looks like you have it cleaned up nicely so put it to work, quick, before it starts rusting! BTW, where you located? Quote Link to comment Share on other sites More sharing options...
devo Posted May 13, 2011 Author Share Posted May 13, 2011 Mark, Thomas, thank you for the replies! I have not been able to weigh it yet, so I'm not sure what it weighs. Serial number appears to be 125526. I'm in Colorado... Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 13, 2011 Share Posted May 13, 2011 Your little beauty was born in 1907 according to AIA. If you can make it out the weight will be under the HB name, it is stamped. Quote Link to comment Share on other sites More sharing options...
clinton Posted May 13, 2011 Share Posted May 13, 2011 Wow that's weird it looks like the face started to delaminate and someone just cut it off. You can repair it by using the Rob Gunther anvil repair method, build up with weld metal using a hardfacing rod Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 13, 2011 Share Posted May 13, 2011 Not only can you; you should! The sweet spot is un faced and you need it for heavy hammering! Rob Gunther's method works GREAT---make sure to follow the pre-heat instructions! Quote Link to comment Share on other sites More sharing options...
devo Posted May 20, 2011 Author Share Posted May 20, 2011 Thanks for the replies, guys... I've reviewed the Robb Gunther method; looks good to me. I assume my HB has a cast or wrought iron base, and tool steel face/top; does AIA identify if my base is cast or wrought? I can't see any joining line, any idea where the "top" and "base" juncture is? I'm excited to be able to fix this thing up. That missing section is in a bad place! Quote Link to comment Share on other sites More sharing options...
philip in china Posted May 21, 2011 Share Posted May 21, 2011 The join between face and base is exactly where it has been cut off! You might want to leave a small step and a "cutting shelf" at the end of your plate. I use my step all the time. Quote Link to comment Share on other sites More sharing options...
