Iron Falcon 72 Posted April 18, 2011 Share Posted April 18, 2011 Rotation on an LG25. Does it make any difference? Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted April 18, 2011 Share Posted April 18, 2011 Don't think so.... Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted April 18, 2011 Share Posted April 18, 2011 Nope, no differnce. I know some guys that will switch the rotation every year. Their thinking is that it will give a more even wear on the hammer. May make a difference if you have a brake on your's. Quote Link to comment Share on other sites More sharing options...
monstermetal Posted April 18, 2011 Share Posted April 18, 2011 It can make a difference if the hammer has a brake, other words your pretty safe running it any way you like Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted April 18, 2011 Share Posted April 18, 2011 Only other reason I've seen is a slack-belt clutch. Quote Link to comment Share on other sites More sharing options...
dsloan Posted April 22, 2011 Share Posted April 22, 2011 The only difference I've seen in rotation. Is if the hammer is used and you only do a partial rebuild. Then you should try and keep rotation the same. I've worked on a friends hammer that he added a new motor, but had the rotation the wrong way. It had actually wore in one way and would not run good in the direction he had it running in. It was an old style hammer. The ram guide had wore on one side more than the other. Once reversed it really woke up. Dave from Diller Quote Link to comment Share on other sites More sharing options...
