ZIG Posted February 23, 2011 Share Posted February 23, 2011 Okay. That large grinding Stone I spoke of a few weeks ago. Well I finally got to it today. Unfortunately, it has a piece broken off one side. Making a 5 inch wide stone go to about 1 1/2 inches For about 8-10 inches of the circumstance. So although the rest is in great shape. And is almost 30 inches tall. Question is :; HOW CAN I REPAIR THIS. I'LL POST PICTURES LATER. BUT IS THERE ANYWAY I CAN BUILD THIS UP WITH DEVCON OR SOME TYPE OF SOMETHING. I'm more concerned about Just filling in the broke piece and making it round again. As far as using it for sharpening. I would have plenty of it left and could Just let It float over That part. I was so excited To find it and a backhoe bucket broke It. Not my doing. But want to at least fix it enough to be worthy of building a stand for it and having it rotate without such a heavy side. So is there anyway to fix this. Cause if not it will be setting in the flower bed and I'll see it everyday and get pissed off When I think about how something that has been it the family For over a hundred years and I finally get it back, just To have it messed up. Any help would be Appreciated. I Am Just upset about it. But its so big And such a pretty Stone. I wanna show it off. More than use it. Help me please. !!!!!!!!! Quote Link to post Share on other sites
BIGGUNDOCTOR Posted February 23, 2011 Share Posted February 23, 2011 Post a pic. Easier to suggest something when we can visualize the problem better. Do you have the chunk that broke off? If so you could epoxy it back on. What ever you do you will want something that wears about the same as the wheel will. You might have to do some experimenting on this with different concoctions like maybe a Fix-All and sand mix. Quote Link to post Share on other sites
pkrankow Posted February 23, 2011 Share Posted February 23, 2011 A pic would help. Using a rotary tool with an appropriate bit you can cut a ring off the stone. Fasten the tool to the frame and rotate the stone by hand to cut it in multiple passes. This is safest as the fractured stone is removed. This will reduce your diameter and true the stone. I presume this is a foot powered stone, so 50-100 rpm is the max it can go, depending on how you pedal. Exceeding this is very dangerous even for a stone in excellent condition. Depending on what you are planing on doing you can profile the stone instead using a similar method. Avoid sharp internal corners. Phil Quote Link to post Share on other sites
MattBower Posted February 23, 2011 Share Posted February 23, 2011 Please be really careful. A stone with structural integrity problems can be very dangerous. Quote Link to post Share on other sites
DanBrassaw Posted February 23, 2011 Share Posted February 23, 2011 A pic would help. Using a rotary tool with an appropriate bit you can cut a ring off the stone. Fasten the tool to the frame and rotate the stone by hand to cut it in multiple passes. This is safest as the fractured stone is removed. This will reduce your diameter and true the stone. I presume this is a foot powered stone, so 50-100 rpm is the max it can go, depending on how you pedal. Exceeding this is very dangerous even for a stone in excellent condition. Depending on what you are planing on doing you can profile the stone instead using a similar method. Avoid sharp internal corners. Phil Rotary tool is a good idea, but what kind of bit would you use for that? Mine didn't have a big chunk missing, but I did have to take about 3/4 off the radius to get rid of a big swell (probably from a chunk breaking off then continued use). I used an old carbide tip saw blade, I held it on it's side, and moved it back and forth using one tooth at a time to cut into the wheel. Once I got past the defect, I just ground into some bar stock to take down the high grooves that were left by my less than perfect dressing method. P.S. Taking 3/4" off of a 20 inch or so diameter wheel took me several dusty and painful hours. The seat on my grinder wasn't meant for that kind of endurance race, and it's a heck of a workout. I don't highly recommend it, but it does work. Quote Link to post Share on other sites
pkrankow Posted February 23, 2011 Share Posted February 23, 2011 Rotary tool is a good idea, but what kind of bit would you use for that? I would start with a rotozip tile bit, or more likely several. I don't know if there is a better tool. A side thought. My wife's grandfather built a horizontal kick grinder. He used a largish natural stone on it, as well as several artificial stones. I think gravity is all that holds the stones in place. I haven't looked at it closely since Grandpa Jim was alive. Phil Quote Link to post Share on other sites
ThomasPowers Posted February 23, 2011 Share Posted February 23, 2011 I think the damage is to the *width* not the diameter and I would not recommend taking that stone down to the thinnest width as it would have little stability then. As mentioned have you thought of mounting it horizontally with the good side up and working on the side of the stone? This type of grinder is not designed for hogging off metal; more for touching up an edge already established by forging and filing. The grind stones for shaping tended to be *MASSIVE*---like 8-12' in diameter and used in factories. Quote Link to post Share on other sites
MattBower Posted February 23, 2011 Share Posted February 23, 2011 Slight thread hijack, but someone recently posted a link here to a site that contains a video of a German swordsmith in Solingten using a good sized old grindestone that looks like it's probably water powered. The grinding starts between 1/3 and 1/2 into the video. Fascinating to watch. The "hockey goalie" shin devices are very interesting. Looks like they mate up with the wooden board that the sword is mounted on to give a consistent bevel angle. http://www.schwertbruecken.de/deutsch/test_video1.htm Quote Link to post Share on other sites
ZIG Posted February 23, 2011 Author Share Posted February 23, 2011 The break is on the side all the way out to the outer / grinding edge. I'll post pictures as soon as I can. But the rock.is five inches thick and since the break.its down to abour 2 inches For about 8 inches of the radius. the wheel.is 30 inches tall. So I have 75% of the grinding surface left. Thought That if I could build it up I might keep it from having such a heavy side And make it useable. But the side ways action is a thought. Cause It does have a good side if used horizontaly. Hate to be so vague about it all. But I ain't able to get it home cause of just getting to It now. The ground is so messed up. So Please bare with me. I'm not trying to be so dumb about it. But I'm not good at explaining things. Thanks For any and all help. Quote Link to post Share on other sites
Mister Bill Posted April 4 Share Posted April 4 You can repair it with JB Weld and use it again. You can make your own stone using a special mortar mix, recipe found on the internet. I've done both successfully. Quote Link to post Share on other sites
Irondragon ForgeClay Works Posted April 4 Share Posted April 4 Zig hasn't logged in since Dec. 28, 2015 and this thread is from 2011, so I doubt he will see your response. Quote Link to post Share on other sites
Frosty Posted April 4 Share Posted April 4 Oh MAN you did it again! We might've really gotten Bill going if you hadn't spoiled it for the rest of us. You're no fun. Frosty The Lucky. Quote Link to post Share on other sites
Irondragon ForgeClay Works Posted April 4 Share Posted April 4 Sorry... I've had a trying day, don't know what got into me. Quote Link to post Share on other sites
Frosty Posted April 4 Share Posted April 4 S'Okay, we all have those days. What say we find someone else to have fun with? Frosty The Lucky. Quote Link to post Share on other sites
ThomasPowers Posted April 5 Share Posted April 5 Hey it's useful information! Does the stone have to be "absolutely dry" to have JB weld work? (Of course I sold off the 4 treadle grinders I got in the hoard.) Quote Link to post Share on other sites
LeeJustice Posted April 6 Share Posted April 6 Nice feature to mouse over the user name to see last log in and such. Quote Link to post Share on other sites
TWISTEDWILLOW Posted April 6 Share Posted April 6 Just curious if the recipe for making homemade stones with special mortar mix also contains jb weld? Quote Link to post Share on other sites
ThomasPowers Posted April 7 Share Posted April 7 I remember old recipes for making your own polishing wheels by using grit and shellac. Quote Link to post Share on other sites
TWISTEDWILLOW Posted Wednesday at 05:15 PM Share Posted Wednesday at 05:15 PM That’s interesting, how well does it work? Quote Link to post Share on other sites
ThomasPowers Posted Wednesday at 06:22 PM Share Posted Wednesday at 06:22 PM Never tried it; it wasn't around in the earlier periods I'm interested in and I'm all for modern abrasives for "modern" work! Quote Link to post Share on other sites
Irondragon ForgeClay Works Posted Thursday at 02:33 AM Share Posted Thursday at 02:33 AM I have a set of knife sharpening, polishing wheels, some sort of hard fiber, that you apply Elmer's glue and roll them in different grit abrasives. They work very well for their intended purpose. Quote Link to post Share on other sites
