caotropheus Posted February 22, 2011 Share Posted February 22, 2011 Greetings I am on my first steps in blacksmithing and for some time I am searching around for a reasonable priced anvil. Well I found one! A bench anvil (I think) 15 kg for about $95. Too expensive? Don't think so. Prices here in Israel for used anvils start at $17/kg and up. The hardy hole is 15 mm x 15 mm, or, in imperial sizes 9/16 of an inch and as you can see by the pictures it is not aligned with the face plate. It has a striking resemblance with this anvil. The rulers are 40 cm and 15 cm. There are some inscriptions not so clear that I hope will help on the identification of the anvil. Something like "GHN RQOKG" or some other possible reading "SCHN PRQOKG". As I said the inscription is a bit blur and most probably I made some mistakes while reading, even using a 8 x pocket magnifier. There are also two numbers that I could identify "86", few cm below the letters. The anvil is steel and not cast iron, to test it I hit it with an hammer and it rings like a bell! cheers Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted February 22, 2011 Share Posted February 22, 2011 Hey Caotropheus, Nice looking anvil. Use it in good health. Mark<>< Quote Link to comment Share on other sites More sharing options...
trying-it Posted February 23, 2011 Share Posted February 23, 2011 Congrats pal! Now watch more anvils appear! Usually the way it happens! Quote Link to comment Share on other sites More sharing options...
