FieryFurnace Posted January 19, 2011 Share Posted January 19, 2011 Since I got my shop up, I have been using a 2'x8' steel table for my vice. I'v got two of these tables. They are light and made more for putting stuff on, not vice work. Little tipsy with a vice mounted on it! So yesterday and today I spend making a little vice stand. The top plate is 1/4" diamond plate. I didn't want to try to tighten bolts down on diamond plate, so I ran some 3/16" plate underneath. The 3/16" plate is about 3/4 the width of the top plate and just shy of the same length! I used 2"--1/4" wall pipe for the legs. I had to do the legs in two pieces because I had pipe cut down to like 26" and I needed 29" or 30". The legs are filled with sand and there is 1/4"x3" flat bar for feet. The back leg has a long piece welded across it with feet for greater strength and stability, once bolted down. It's got a little tool rack and tool shelf. It is very firm and very solid even though it isn't bolted down yet. The back leg! Thoughts??? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 19, 2011 Share Posted January 19, 2011 Is the leg fastened tight? I don't see anything under the bottom of it. I get more stability from the leg on the ground than the mounting. I understand leg vises get cut, bent and broken. Phil Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 19, 2011 Author Share Posted January 19, 2011 The leg is attached very firmly. There isn't a sixteenth of an inch of play in that piece of pipe. I was very fortunate to have the perfect size pipe to fit my leg instead of having to forge something to fit! Quote Link to comment Share on other sites More sharing options...
eric sprado Posted January 19, 2011 Share Posted January 19, 2011 I think Phil meant "is there anything UNDER the vice leg?" That is what gives the post vice it's name and strength. The bottom of the leg is what absorbs your blows..... Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 19, 2011 Author Share Posted January 19, 2011 Ok 10-4! No there isn't anything there! Funny thing, been smithin' for 5 years and never thought about base support. I've always worried about left to right! It's a wonder I haven't broken something! Will add! Thanks for pointing it out! Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted January 20, 2011 Share Posted January 20, 2011 Dave, you just keep amazing everyone with your enginuity and determination to get a full shop built. Good to see a young fella with that kind of drive. Great work. Thanks for sharing. :D Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted January 20, 2011 Share Posted January 20, 2011 Dave, I like the fact that you learn as you go and adapt. Bravo! Nice job on the vice table. Mark<>< Quote Link to comment Share on other sites More sharing options...
primitiveprecision Posted January 20, 2011 Share Posted January 20, 2011 Hey it looks to me like a masterpiece work in progress. Before you know it you will have 42 hammers and 67 tongs hanging around it and you will surely never regret having spent the day or two to put it together. I have two post vises that have been sitting around for a year and I finally just mounted one to my 4' x 5' fixture table. The thing weighs about 1900 lbs, so I don't need to bolt it down, but that post to the ground makes all the difference for sure. nice work! Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 20, 2011 Author Share Posted January 20, 2011 I understand leg vises get cut, bent and broken. Phil Ehemmm...well...'cough, cough'.... I've got a wee little confessiong to make! I cut it off! I had to, to get it on my demo trailer, and at the time it was the only vice I had. I'll see if I can't hunt up a piece of 7/8" or something to xtend the leg back out! Quote Link to comment Share on other sites More sharing options...
MLMartin Posted January 21, 2011 Share Posted January 21, 2011 O nooooooo, without the foot it will brake the mounting bracket after much hammering on, i don't know how you used it on the trailer without a leg anyway, seems like you could have just unbolted it from the mounting bracket and rebolted it any time to got some where and just let the leg rest on a board on the ground Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 21, 2011 Author Share Posted January 21, 2011 O nooooooo, without the foot it will brake the mounting bracket after much hammering on, i don't know how you used it on the trailer without a leg anyway, seems like you could have just unbolted it from the mounting bracket and rebolted it any time to got some where and just let the leg rest on a board on the ground Oh it's still got enough of a leg to put support under and everything. Yea it was a pretty stupid idea looking back on it! Oh well! On thing is, I haven't done a lot of hammering in the vise until now.....just now learned some of the jobs that require a lot of that. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 21, 2011 Share Posted January 21, 2011 Just weld a piece of angle under as a shelf and a piece of rod or pipe to the floor (or something like that) as an extra leg for the stub leg to sit on, or wrap a strap under the pipe to cradle the leg end. You may want to, eventually at some point, make a shorter table for striking on, and you will need a cut off vise leg to do that with. Phil Quote Link to comment Share on other sites More sharing options...
