Dan H Posted October 31, 2010 Share Posted October 31, 2010 I'm sure this topic has been discussed and re-cussed infinite times but I need to add my 2 cents. I bought a small champion rivet forge and I need the helical cut gear inside the blower. Would anyone happen to have one around that they'd be willing to let go of? I can't find one anywhere. I am brand new and I want to get started as soon as I can. Thanks in advance for any and all help. Dan Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted November 1, 2010 Share Posted November 1, 2010 I'm sure this topic has been discussed and re-cussed infinite times but I need to add my 2 cents. I bought a small champion rivet forge and I need the helical cut gear inside the blower. Would anyone happen to have one around that they'd be willing to let go of? I can't find one anywhere. I am brand new and I want to get started as soon as I can. Thanks in advance for any and all help. Dan If you can provide us with a model number (such as Champion 400) it would be helpful, but even better a couple of pictures. Folks would probably need some measurements on the diameter of the gear you need etc. Good luck! Quote Link to comment Share on other sites More sharing options...
Dan H Posted November 1, 2010 Author Share Posted November 1, 2010 I tried to find a model number on it but there's nothing cast into the housing anywhere I could find. I'll see if I can get some pictures of it to help with identifying it. The gear I need is a 4 1/2 inch diameter helical gear with 72 teeth. It is driven my the crank gear and drives the fan shaft. I don't think it's a 400 - weren't those numbers cast into the casing? Like I said, I'll try to get some photos. Thanks for any help. Dan Quote Link to comment Share on other sites More sharing options...
jimbob Posted November 1, 2010 Share Posted November 1, 2010 I'm sure this topic has been discussed and re-cussed infinite times but I need to add my 2 cents. I bought a small champion rivet forge and I need the helical cut gear inside the blower. Would anyone happen to have one around that they'd be willing to let go of? I can't find one anywhere. I am brand new and I want to get started as soon as I can. Thanks in advance for any and all help. Dan I had one I took the gear to a machine shop and had them make me a new one the cost was around $35.00 Quote Link to comment Share on other sites More sharing options...
Dan H Posted November 10, 2010 Author Share Posted November 10, 2010 I had one I took the gear to a machine shop and had them make me a new one the cost was around $35.00 I'll call around to some local machine shops and see what they can do for me. Thanks for the advice. Dan Quote Link to comment Share on other sites More sharing options...
jimbob Posted November 10, 2010 Share Posted November 10, 2010 I'll call around to some local machine shops and see what they can do for me. Thanks for the advice. Dan they can also yellow weld and build up the broken teeth and re-cut them Quote Link to comment Share on other sites More sharing options...
