Agita Posted October 29, 2010 Share Posted October 29, 2010 I know its probably simple yo most of y'all but How do you go about making a Third and for a pritchhel hole ? I can form it perfectly but what about tempering to get it not too springy but not too Stiff? I wish my original teacher was around to ask. Thanks to anyone in advance. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted October 29, 2010 Share Posted October 29, 2010 Are you talking about a third hand or a hold down? My third hand is on a seperate base and I can move it form the forge to the anvil, etc. It supports long pieces of metal while in the forge or laying on the anvil. I also have a hold down to fit my pritchel hole to hold something down while I use my handled hot cut or a chisel, etc. Both are just mild steel and not hardened at all. :D Quote Link to comment Share on other sites More sharing options...
Agita Posted October 29, 2010 Author Share Posted October 29, 2010 Sorry bout that, I meant a Hold Down. We called them a third Hand but what you say makes sense. I have worked for almost a year now without one and Now I find myself in need. Made two. One springs back up and the other I needs to reform. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted October 29, 2010 Share Posted October 29, 2010 Heat the curved part of the hold down and slightly straighten the curve. Try that, first. I suspect that it is bent too tight. :) Quote Link to comment Share on other sites More sharing options...
Agita Posted October 29, 2010 Author Share Posted October 29, 2010 I'll try it in the morning. Thanks Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted October 30, 2010 Share Posted October 30, 2010 The hold down needs to have just the right curve so that it "chokes" into a top edge of the pritchel hole and the opposing edge at the bottom. It is a matter of experimentation. While on the subject of "third hands" however, Francis Whitaker showed a third hand that fit into the pritchel hole, and he used it to support a stock length when lap welding. I've made one. You forge an anvil-thickness length of stock, making it round at the end of a bar, reduced from a preferably square cross section, to be placed for a snug fit in the pritchel hole. You'll have probably 12" to 20" sticking vertically above the anvil face. A hot, 90º bend will take place at the anvil face. Insert the hot bar, pull it down and hammer a right angle. The horizontal, straightened portion can now pivot on the far side of the anvil to support a piece for a lap weld. http://www.turleyforge.com Granddaddy of Blacksmith Schools Quote Link to comment Share on other sites More sharing options...
Conrad Hodson Posted October 30, 2010 Share Posted October 30, 2010 Heat the curved part of the hold down and slightly straighten the curve. Try that, first. I suspect that it is bent too tight. Go ahead and try that. (I assume you're talking about the traditional one-piece holddown that's shaped something like a numeral 7, right? If you still have trouble, try thinning down the "neck" of the extended part. Mine used to bounce out all the time until I reduced the cross-section behind the gripping pad by about one-half. It also helps to roughen the shank; I cross-peened the part of the shank that's inside the pritchel hole during use; it holds better that way. (Doing this on one that's used on a woodworking bench wears out the holes sooner--not generally a problem on an anvil.) Conrad Hodson Quote Link to comment Share on other sites More sharing options...
