Posted
Hi guys
just a quick question ive found a new place to put my coal forge now, but am in the process of getting it set up, ive located a 100mm (4inch) plastic fan that will shift approx 280m3 of air an hour ive set it up with the idea of just seeing how it will run, ( as i was given it for free)i have a bottom blast forge and am planning using coke once the fan is running the air supply seems well how can i explain it is suppose its medium at best, im just wondering if this would be man enough to get the right amount of heat, also am wondering what amount of airflow will be required in terms of extraction. I ws thinking of a plastic fan as there is a hydroponics shop near where i live and they do various sizes that are relitively cheap, like the rest of the tools i require i am finding purchasing the right equipment rather difficult so am trying to make do with what there is freely available
If my post seems a bit ignorant please forgive me as im a relitively new to this
thanks
Nathan
Posted
Hi guys
thanks
Nathan
Just a quick update done a quick calculation
if cfm is cubic feet per minuet, and my fan is second hand so may not be effiecnt as it once was, so say around 200 meters cubed per hour converting this into cfm is roughly 120cfm, does this sound adequate, the same shop also sell control switches which i can adjust the fan speed if it were to high which it when i place my hand over the vent doesnt seem to be, its like taking a deep breath then blowing on your hand about 4 inches from your mouth????? if that makes sense
Posted
Hi Nathan, Try what you have and see how it performs, if it doesn't work satisfactorily, you can use that one for an extractor fan.
Posted
none of your information gives us any indication of what kind of pressure it can shove through a stack of fuel rather than just in a free air test.
In general it's easier to run a test with the forge you intend to use it for and see if it works without straining itself.
