gking Posted July 27, 2010 Share Posted July 27, 2010 What would you use as a rust inhibitoron grill sets and other item exposed to heat tripods, campgrills, and the like? I use a beeswax and linseed oil mix for my creations this far but wont that melt right off? Quote Link to comment Share on other sites More sharing options...
JKindy Posted July 27, 2010 Share Posted July 27, 2010 I am sure more experienced will chime in, but... I use Olive oil on my cast iron pans to season them. That is basically what you are doing. Heat them up, coat with oil, keep them warm for about an hour, then coat them again. When seasoning a new pot or pan I will do this 3-4 times at 400*F. Hope that helps. Jeff Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 27, 2010 Share Posted July 27, 2010 I am sure more experienced will chime in, but... I use Olive oil on my cast iron pans to season them. That is basically what you are doing. Heat them up, coat with oil, keep them warm for about an hour, then coat them again. When seasoning a new pot or pan I will do this 3-4 times at 400*F. Hope that helps. Jeff I like shortening over oil, I find it provides a more even coating that is less gummy. Otherwise about the same, oven heating at over 250F does the trick, 425F while cooking works fine too. It is rather forgiving. It will need reapplied regularly, but the directions are so simple it is just maintenance. For pots and pans many say "annually whether it needs it or not" or whenever the coating looks less than fresh. Phil Quote Link to comment Share on other sites More sharing options...
John B Posted July 27, 2010 Share Posted July 27, 2010 Bacon Grease works well Quote Link to comment Share on other sites More sharing options...
JKindy Posted July 28, 2010 Share Posted July 28, 2010 Mmmmmmmmmmmm...BACON! I use bacon grease on my self made bows to seal the wood. There is a lot of uses for the goodness of bacon! Quote Link to comment Share on other sites More sharing options...
infinityblacksmithing Posted July 28, 2010 Share Posted July 28, 2010 I'd agree with what everyone is saying about seasoning the pieces, as that is the time tested method. However, you could also use a high temp paint for parts that won't be touching the food. Quote Link to comment Share on other sites More sharing options...
Terrance W Posted July 26, 2020 Share Posted July 26, 2020 As I have posted else where, Cast iron pots and pans will do will with Flack seed seasoning, using an outdoor Fryer/Boiler I heat my cast iron to 400*F apply Flack seed oil and hold till smoking stops and apply another coat. This produces' a deep dark coating that is extremely hard to the point you can use metal utensils without worry of it chipping. I do this once a year to all my cast iron. do not apply too heavy and don't let it pool or it will not dry well and be sticky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 26, 2020 Share Posted July 26, 2020 To keep the oil from pooling, I turn the pans upside down with a cookie sheet under it and bake at 400° F several times for a new pan. After they are well seasoned, just wipe them out with a paper towel to clean. Quote Link to comment Share on other sites More sharing options...
