Junksmith Posted June 11, 2010 Share Posted June 11, 2010 I have no plans to giveup my homemade anvil, but at 250 pounds it is getting a little cumbersome to take to demos. After much searching and fruitless bidding I finally located this Hay-Budden farriers anvil. It is 160 pounds (a veritable featherweight) and interesting in that it has an unusually large horn and long heel. I've never been one to stand on ceremony, but it's also nice to have a more traditional looking anvil for demos. Now to build a stand! It seems only right for this pic to be a sepia tone. Quote Link to comment Share on other sites More sharing options...
archiphile Posted June 11, 2010 Share Posted June 11, 2010 Cogratulations. Two-hundred fifty pounds is a lot to move often. Makes me glad for my 186 pounder. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 11, 2010 Share Posted June 11, 2010 I've been trying to stock up on 90-125# anvils to take on the road teaching. My 153# PW stays home these days! It used to travel when I weighed the same as it... Quote Link to comment Share on other sites More sharing options...
Doug C Posted June 12, 2010 Share Posted June 12, 2010 This looks identical to my anvil which is also about 160LB. I don't hold it they way you are too often! Nice anvil but the heal rings like the dickens. Quote Link to comment Share on other sites More sharing options...
Junksmith Posted June 17, 2010 Author Share Posted June 17, 2010 This looks identical to my anvil which is also about 160LB. I don't hold it they way you are too often! Nice anvil but the heal rings like the dickens. You ain't kiddin'. The horn rings a bit too much too, but not like that heel. I'm going to try and put a section of heavy rubber mat under it on the stand but I'm not optimistic. I guess I'll just keep aiming for center mass as often as possible. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted June 17, 2010 Share Posted June 17, 2010 Make some brackets holding the feet down, and design them so you can tighten them up as needed. It is surprising how much ring that will take away. The rubber mat is still a good idea. Phil Quote Link to comment Share on other sites More sharing options...
Junksmith Posted June 18, 2010 Author Share Posted June 18, 2010 Make some brackets holding the feet down, and design them so you can tighten them up as needed. It is surprising how much ring that will take away. The rubber mat is still a good idea. Phil Thanks for the advice Phil. Demos are the biggest draw I have for craft fairs and I'd hate to chase people away with that ring. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted June 18, 2010 Share Posted June 18, 2010 Well, by making the brackets adjustable you can LOOSEN them to have MORE ring to attract people too! There is such a thing as too much of a good thing though. Phil Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted June 19, 2010 Share Posted June 19, 2010 Might try a carriage bolt in the pritchel hole. Slip fit about a 5 incher. Pop it out to draw a crowd pop it in and it gets quieter. Works on both my H-Bs. Ken. Quote Link to comment Share on other sites More sharing options...
adamj Posted June 19, 2010 Share Posted June 19, 2010 like dragon said something laying on the face will work i used a homemade anvil in class that had one heck of a ring and i would put a c clamp on the end of the hill works great Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted June 19, 2010 Share Posted June 19, 2010 That shape seems fairly common to the farrier anvils. Not ideal for most standard smithing purposes but most of the time you'll only use a small section of the anvil and if you choose the section over the main body it will perform pretty nearly as well as a standard shaped anvil anyway. Put on some good shooter's ear muffs and RING IT till you get a little crowd. Then you can take the muffs off and work on the quieter portions of the anvil while they watch. The shape IS SEXY looking!!! Quote Link to comment Share on other sites More sharing options...
