K. Bryan Morgan Posted June 8, 2010 Posted June 8, 2010 I haven't posted for a little bit. Been kinda busy. But I have been forging . I made a trammel and a J hook. I got an order for four J hooks. I've made them before, but not with an arrowhead finial before. So I started with some 3/8th mild got the arrow head portion upset somewhat to make it larger and then isolated what I wanted to make the arrowhead part with.. It didn't work out so good... I broke one off hammering it too cold. Knew better too.. but it will make a nice leaf someday. And the other one .. eh..just not thrilled with it...There are some parts of it I like.. the twist came out nice I think, and the hook and finial scroll for that looks nice too.. I did a flat taper then rolled it. On the trammel, I did what seemed an easy way to do it. did a flat taper on one side and made the hook out of that for the hanger with a scroll and punched the hole for the angle. Then the other holes. Made the hook that you hang the pot off of and figured out pretty quick I had the angle for the part that goes through the holes to long. Got that fixed and I'm quite happy with it. First one I made and I like it. Enjoy. Quote
alfadee Posted June 8, 2010 Posted June 8, 2010 now i see what you wanted to do. came out really nice! yesterday i could not really imagine what you meant with the arrowhead on the top end. but what you did really looks like kind of ancient obsidian point. my mom told me i should make some hooks for her purses, she would love them! especially because they hang next to my bows and arrows:D david ps: uhmm first post i think, perhaps i should introduce me:-P Quote
pkrankow Posted June 8, 2010 Posted June 8, 2010 What size is the material for the trammel? Looks good! Phil Quote
K. Bryan Morgan Posted June 8, 2010 Author Posted June 8, 2010 Thats 1\4" by 3/4" by 13" long to start. I bent the bottom about one inch up and the hook is about 6" drawn out give or take. I was going to use 3/16" holes but ended up using 1/4" instead and I spaced them every 2 inches. It was a little easier seeing how the holding hook is made out of 3/16" rod. I could have made it work forging out the rod alittle bit..but why go to all that trouble just make the holes alittle bigger and done. Quote
Paul42` Posted June 9, 2010 Posted June 9, 2010 Here's a trammel I made the other day. It's pretty big... adjustable 18" to 25" & still needs a coat of high-temp paint. Quote
K. Bryan Morgan Posted June 9, 2010 Author Posted June 9, 2010 Hey Paul, thats really a nice one.. I need to get a better picture of mine.. Thats what I get for takeing pictures at Nine oclock at night. Quote
Frosty Posted June 11, 2010 Posted June 11, 2010 That looks really nice Bryan and best of all it has a personality all it's own. Once you get it down these are pretty easy to make but they all look pretty much alike. Having one that has it's own look is a big plus. Well done Buddy. Frosty the Lucky. Quote
K. Bryan Morgan Posted June 11, 2010 Author Posted June 11, 2010 Thanks, that means a lot to me. It works. I guess that is the main test. I pulled on it hard. I'm sure I put more than 50# of pull on it and nothing. So I know it will hold a pot of beans over a fire. :) Quote
Frosty Posted June 15, 2010 Posted June 15, 2010 Thanks, that means a lot to me. It works. I guess that is the main test. I pulled on it hard. I'm sure I put more than 50# of pull on it and nothing. So I know it will hold a pot of beans over a fire. Ah. . . Right to the important consideration! Not spilling the beans is by far the most telling trait of a proper trammel. Frosty the Lucky. Quote
K. Bryan Morgan Posted June 15, 2010 Author Posted June 15, 2010 Beans, beans the more you eat.....as the old poem goes. I guess I could just do it with several S hooks but I got tired of making them. This was a lot more fun. :D Quote
CurlyGeorge Posted June 18, 2010 Posted June 18, 2010 Good job Bryan. The trammels are fun to make. That one looks nice. Paul, I like yours,too. They both look plenty sturdy. Quote
K. Bryan Morgan Posted June 18, 2010 Author Posted June 18, 2010 Thanks George, its plenty strong. Still trying to get back out to the forge and finish up a camping set.. been so busy with other things I just havn't had time....When I get it done I'll post some pics of it too. Quote
