dashand Posted June 4, 2010 Share Posted June 4, 2010 has anyone have information about using a hi temp vent fan (simlar to a power venter for a furnace) to keep a chimney drawing when the chimney needs to be short? maybe 2-3 feet above the roof but at the lowest edge of the roof. what temperature air is going thru a flue? the fire is obviously very hot but the air going up the chimney is mixing with alot of ambient room air. am i howling at the moon with this line of thinking? thanks Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted June 4, 2010 Share Posted June 4, 2010 I'm eager to hear the responses to this. I have just installed a booster fan in my chimney, but haven't had a chance to try it yet. I don't know if the fan motor will take the smoke and heat. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted June 4, 2010 Share Posted June 4, 2010 Look at using a draft inducer, no moving parts in the hot gasses, but instead injects air in the correct direction to move the rest of the gas column. Many places including Grainger sell the inducer fan, but you should talk to someone to help you design it, I don't know enough. Ron Reil talks about it on his website with his vent hood. Phil http://ronreil.abana.org/shop.shtml Quote Link to comment Share on other sites More sharing options...
dashand Posted June 4, 2010 Author Share Posted June 4, 2010 i spoke with a technical person at tjernlund fans. they go back to the era of coal heat and still have a vent that they use for solid fuel (wood) that he recommended. it is a radial bladed fan with the motor out of the airstream and is installed by cutting a section out of the piping. also found a fan at rockford chimney supply website for use with solid fuel. i dont remember what the btu heat output is for coal but i suspect these fans are (particularly the tjernlund) are robust enough for the high temps. i will try to get a look-see at ron reils site to check his solution. Quote Link to comment Share on other sites More sharing options...
Steve McCarthy Posted June 7, 2010 Share Posted June 7, 2010 Mount a blower off to the side of your chemny.Connect pipe from the blower outlet to the chemny at a sharp angle upward. This keeps the blower/fan out of the heat and smoke, while keeping a good draft going. Just like an induced draft fan on a wood fired boiler. Quote Link to comment Share on other sites More sharing options...
