rakessler Posted April 8, 2010 Share Posted April 8, 2010 Hello I am looking for someone in the atlanta Ga area, that has built a tire hammer. Mine is finally getting assembled, I am going to very soon need the allignment Gauge that clay uses to allign the hammer with the anvil. I could make one but I figure with the popularity and all the hammers I have seen. I figure someone out there must have the gauge already assembled, and perhaps would let me use theirs for a little while. I can only hop and wish. RalphAndrewKessler I live in central ga. 7708305670 I though I would add some info, the gauge sets the height of the 50 pound hammer head and anvil. The gauge also sets every thing parallel because as the head is set on the gauge which is already setting on the anvil you are also putting in place the 4x4 that hold the hammer assembly. I hope this helps those that are not familiar with the Tire Hammer. I was hopping that someone who has already been through the process would help in sharing the gauge discriped in the builders manual. Most would only be using the gauge once or twice. Thanx again RalphAndrewKessler Quote Link to comment Share on other sites More sharing options...
monstermetal Posted April 8, 2010 Share Posted April 8, 2010 Let me know if hopping helps Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted April 9, 2010 Share Posted April 9, 2010 If you are talking about a gauge to check how the tup and anvil are aligned in relation to each other then why not just use feeler gauges? Quote Link to comment Share on other sites More sharing options...
