clinton Posted April 3, 2010 Posted April 3, 2010 We just got a cabinet for the bathroom it was hand made pine kind of distressed wood looking. My girlfriend wanted a latch for it as the doors are a bit warped and will not stay shut. So I have to go and open my big mouth and say that I could make a latch and some hinges as well. (doohht) Well I have some yellow brass that was kick plates on doors that I saved from the trash on a job a few years back, I kept it real simple nothing fancy and these are my first hinges so it was a good learning experience. I used 3/16 stainless for the hinge pins and upset the end a little so they will not slide out I think I am going to shorten the latch about 1/2 an inch Quote
Dodge Posted April 3, 2010 Posted April 3, 2010 nice job. Especially for a first attempt. Did you use a jig to roll the hing tubes? They look nice and uniform. Quote
Fe-Wood Posted April 4, 2010 Posted April 4, 2010 they look great Clinton but- ah, how are you going to mount them¿? :P Quote
clinton Posted April 4, 2010 Author Posted April 4, 2010 nice job. Especially for a first attempt. Did you use a jig to roll the hing tubes? They look nice and uniform. I did not use a jig this brass moves easy I just clamped in the vice and hammered down then inserted the round stock and continue hammering until it closes up finishing with sharp edge on anvil. A jig would be a great idea but with a short run like this I did not want to take the time to make one. Thanks for the vote of approval Quote
clinton Posted April 4, 2010 Author Posted April 4, 2010 they look great Clinton but- ah, how are you going to mount them¿? I am planning to just use some brass screws I thought about making some nails to attach but this wood is old (may end up a pile of kindling) and if I nail them on and need to adjust that would be a problem so I am going to take the easy way and buy a pack of screws Quote
southernforge Posted April 4, 2010 Posted April 4, 2010 ...this wood is old (may end up a pile of kindling) and if I nail them on .. Apply linseed oil to stabilize old wood. Quote
Fe-Wood Posted April 4, 2010 Posted April 4, 2010 Apply linseed oil to stabilize old wood. and predrill 3/4 the nail hole using a nail of the same size. I will share some other tricks if you want the look of nails.... Quote
clinton Posted April 12, 2010 Author Posted April 12, 2010 Got the hardware mounted this weekend I think it came out pretty nice and my girlfriend is happy, got me a case of beer and a bottle of jim beam out of the deal so I think I made out good. Of course the "hardware store" did not have enough screws to finish so I had to short screw it for now I went with a # 7 x 3/4 brass screw with a round head and straight slot Quote
pkrankow Posted April 12, 2010 Posted April 12, 2010 Handsome! Will look better with all the screws in. Slotted will keep the older look too. Phil Quote
Frank Turley Posted January 17, 2012 Posted January 17, 2012 fe wood, I want the 'trick' to get the nail-look. Quote
