Fe-Wood Posted March 2, 2010 Share Posted March 2, 2010 I needed a Guillotine Tool to make some 90 degree bends today. So I looked at the stock I had and came up with this. If I tried real hard, I could stretch the production time to about 1 hour... Maybe. I only took the one picture but I started with .75x1.5 hot roll, all out of square and everything. I cut 4 pieces at 6" long. These became the frame, "V" tool and base. Then I cut 2 pieces of .25x1 to 2.625". these became the top sides. The rounds are .5 or .625 (I never measured it) I placed these to use for the 90 bend supports. I will weld them up better later, I wanted to be sure it worked first. With the steel hot and using the tool with the "v" point, This setup bends .25x1" easily in 3 hits and a little truing up in the vice. I made the tenoning tool while I was at it, but haven't tried it yet. The other "V" block is for 2 bends that are very close to each other. I included a picture of the parts I made to. They are made out of mild steel but if I work everything hot, it should last for a while.....Can't afford the press yet (Bought a lathe instead) :) Quote Link to comment Share on other sites More sharing options...
DennisG Posted March 2, 2010 Share Posted March 2, 2010 nice! machined tracking? Quote Link to comment Share on other sites More sharing options...
ArtWerkz Posted March 2, 2010 Share Posted March 2, 2010 Looks good Fe, no fair you have a mill... Nice tool, sort of like that smithing magician. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted March 2, 2010 Share Posted March 2, 2010 "Fast, Cheap and easy"? Sounds like you're describing me! Good job FE! And how are your brothers, Fi, Fo, and Fum? Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted March 2, 2010 Author Share Posted March 2, 2010 Thanks guys- Yes, it is tracked with a machined slot about 1/8" deep. Fi is fine! Fo is forever lost in the forest of fortune and Fum is fumbling around in the dark looking for a fumar to share with his bro Fe. Thanks for asking FCE! Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted March 2, 2010 Share Posted March 2, 2010 That is a nice simple way to do it. I've been thinking about a similar set up but the channel for the dies made out of angle iron. That does give me an idea. I would also have to bolt or rivet it all together. I really need to learn how to weld. Quote Link to comment Share on other sites More sharing options...
trying-it Posted March 2, 2010 Share Posted March 2, 2010 Mills, lathes, and other pieces of equipment from the mechanical revolution era being used in a blacksmithing shop? Tell me it aint so!!! BTW: Nice work on your end! Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted March 3, 2010 Author Share Posted March 3, 2010 I never said I had a revolution era shop maybe I implied it Besides, it not what you do, it how you do it... or something like that.... Quote Link to comment Share on other sites More sharing options...
