Winston Posted December 31, 2009 Share Posted December 31, 2009 I am going to make a couple of things for the wife to go in the bathroom. One thing will be a towel rack. I do not have any experiance in finishes. I read about finishes for damp environments, but they related to outside. This is a small bathroom and everything sweats when taking a shower. She wants a dark brown or black finish. I could just clear coat with something. Ok to the question: Do I need to worry about rust? What finish will not rub off with towels rubbing over the bar? Will a clear coat wear off? I know I could just paint them, but I was wondering if I could do something better? Thanks. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted December 31, 2009 Share Posted December 31, 2009 Clear satin urethane works well - I made a towel rack about ten years ago for our bathroom that was sandblasted, followed by wire brushing to provide some shine then coated with urethane. It has neither rubbed off or started rusting. You could paint it flat back and clear coat with urethane (or acrylic lacquer), or "heat blue" w/CC, or wire brush w/CC, etc. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted December 31, 2009 Share Posted December 31, 2009 i use rustoleum cristal clear . it works well and dries clear it jenerally darkens the iron wich looks good . i tumble my ironwork before finishing it . works good lasts a long time! Quote Link to comment Share on other sites More sharing options...
Winston Posted January 1, 2010 Author Share Posted January 1, 2010 Thanks! That was what I was looking for. Quote Link to comment Share on other sites More sharing options...
dief Posted January 1, 2010 Share Posted January 1, 2010 I use Permalac Laquer for both indoor and outdoor projects. The stuff is super tuff. You can also add solvent dyes to add color. Quote Link to comment Share on other sites More sharing options...
HWHII Posted January 1, 2010 Share Posted January 1, 2010 For small parts I like to use Krylon gloss acrylic. It is the one that does not have a ball bearing in it when you shake it. There are other brands that also do not have a ball bearing in it and they work just as well. I have been told the reason for not have a ball bearing in it is because there is only one ingredient in it and there is nothing else to mix. I apply it when the part is warm to the point it is hard to hold on to. Apply three coats as it cools. For larger parts I use Permalac from Scuplt Nuvo in the one gallion can. I load it into a gravity fed spray gun and just start shooting. HH Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted January 1, 2010 Share Posted January 1, 2010 I have wondered about this myself... Bathroom finishes etc. applied over towel bars and the like. Hanging a damp towel on a piece of steel or copper with a clear finish, sounds like you guys have found your chosen finishes to provide suitable protection over the long run. I have hesitated trying this because of the way finishes act on wood products made for this purpose. They always seem to fail after about a year or so. My wife requested a hanger for our bathroom, I will try some of your meathods, Thanks! Quote Link to comment Share on other sites More sharing options...
Mark Aspery Posted January 2, 2010 Share Posted January 2, 2010 I am going to make a couple of things for the wife to go in the bathroom. One thing will be a towel rack. I do not have any experiance in finishes. I read about finishes for damp environments, but they related to outside. This is a small bathroom and everything sweats when taking a shower. She wants a dark brown or black finish. I could just clear coat with something. Ok to the question: Do I need to worry about rust? What finish will not rub off with towels rubbing over the bar? Will a clear coat wear off? I know I could just paint them, but I was wondering if I could do something better? Thanks. I have used 'Mop & glow' for your kitchen floor from the local supermarket with good results. If it gets scratched just re- apply over the scratch and the 'Mop & Glow will repair itself. Quote Link to comment Share on other sites More sharing options...
John B Posted January 2, 2010 Share Posted January 2, 2010 While a more expensive option, stainless steel works well. Do the vinegar soak and wire brush for the bright finish. Just wire brush for the forge finish. If you are going to wire brush stainless, its preferable to use a wire brush with stainless bristles or brass, otherwise the forged stainless will be contaminated and end up with a rust discoulered appearance. Quote Link to comment Share on other sites More sharing options...
fat pete Posted January 3, 2010 Share Posted January 3, 2010 i use krylon also for outside things or things that need to sparkle a little...that will rust outside around here after a while...i think its how clean the metal is from hand oils and other crap...but in a home i try and keep it to the wax and oil coating ...easily touched up with a little wax rubbing in...at least let it get a neat worn patina....when and if you like what it looks like then "freeze" the patina with a clear laquer works ofr me so far..... Quote Link to comment Share on other sites More sharing options...
John B Posted January 4, 2010 Share Posted January 4, 2010 Thanks John, I always forget that detail. Yes, me too Gerald, but I put it down to my age, and call it a 'senior moment' I think its also like most things, you just don't realize actually how many little details go in to producing a finished item or even part of an item and its so easy to omit one or two Quote Link to comment Share on other sites More sharing options...
Blacksmith Jim Posted January 4, 2010 Share Posted January 4, 2010 I've forged a hanger for the shower head in our old bathroom. I left on a very thick coat of beeswax, and used it as is. It never rusted in over the year and a half we used it. Left it at the house, and haven't heard anything from the new folks about it. Quote Link to comment Share on other sites More sharing options...
