45 and 90 deg stops for chop saw
Got tired of always having to use a square when switching the chop saw back and forth from 45 and 90 deg settings. Tonight, I stopped and set the saw dead on 90 deg then I drilled the fence and base plate and inserted a split pin and then did the same for 45 deg. To move it between the two settings, I just use a pair of vicegrips to wiggle the pin out. Frustation came be a great motivator at times.
  • 2 weeks later...
