Bigcity Posted December 8, 2009 Posted December 8, 2009 ok im thinking about switching from coal to charcoal mainly because i that its a cleaner fire from what i have read couple of questions can you use the same air blast as coal? is it easyer to weld with than coal? and any other pointers never have used it just wondering Quote
Mark Wargo New2bs Posted December 8, 2009 Posted December 8, 2009 I use charcoal (natural hardwood, not briquettes) in my brake drum forge. I get the air from a $5 oscilating fan from Wal-mart and that gets it plenty hot. You will go through quite a volume of charcoal relative to coal. Quote
Rob Browne Posted December 8, 2009 Posted December 8, 2009 It doesn't take the same volume of air so you will have to reduce your air blast. Quote
781 Posted December 8, 2009 Posted December 8, 2009 I use home made charcoal from 2X4s ect. Gets plenty hot enough to weld but gives off a lot of cinders that like to fload around the shop. I need to add a hand full of charcoal every heat or sooner Too much air will blow some of the charcoal out of the fire especially the fines. Fines dont coke up like coal. I dont have a very deep fire pot so I need to add burning charcoal inder the stock as well as add above the stock. Quote
ThomasPowers Posted December 8, 2009 Posted December 8, 2009 When I switch my forge from coal to charcoal I place a couple of fire bricks next to the firepot to make a narrow deeper fire. It does use a lighter blast. Quote
Bigcity Posted December 9, 2009 Author Posted December 9, 2009 ok thanks for the info i dont have fire bricks but i got some good sized c channel i could use Quote
son_of_bluegrass Posted December 9, 2009 Posted December 9, 2009 You'll do better with something that insulates. A charcoal fire won't use as much fuel if the fire pot is well insulated. If you use firebricks then you can reshape the pot to suit the work better. ron Quote
Bigcity Posted December 9, 2009 Author Posted December 9, 2009 ok i need to make a deeper firepot anyway i might just do that then Quote
reefera4m Posted January 4, 2010 Posted January 4, 2010 Charcoal is cleaner than coal but so is coke. Converting coal to coke is just like converting wood to charcoal, you burn off the impurities. If you're not making you own charcoal then it will be cleaner. It will take more charcoal that coal/coke because there just isn't as much energy stored in charcoal as in coal/coke. You might want to look into purchasing coke rather than raw coal. Quote
