Kendrick Posted August 26, 2009 Share Posted August 26, 2009 I bought this as part of a lot of blacksmithing tools at an auction a while back. I bolted it to the bench and have used it once or twice for bending but have no idea what it really is. Link to comment Share on other sites More sharing options...
Mike Ameling Posted August 26, 2009 Share Posted August 26, 2009 To me it looks like the anvil/tool used for working the square link drive chains on lots of farm machinery. Possibly even for working with roller chain. The right end is the classic form for working the square drive links. And the other end looks more like it would be used for punching out the pins on roller chain. Just a thought. Mikey Link to comment Share on other sites More sharing options...
arftist Posted August 26, 2009 Share Posted August 26, 2009 That is a double ended fimjigamor with triple parralell perpendicular slots. Very rare. Link to comment Share on other sites More sharing options...
Armand Tatro Posted August 26, 2009 Share Posted August 26, 2009 Mike ameling is correct! Armand Tatro Link to comment Share on other sites More sharing options...
Kendrick Posted August 27, 2009 Author Share Posted August 27, 2009 Thanks guys. Link to comment Share on other sites More sharing options...
CurlyGeorge Posted August 28, 2009 Share Posted August 28, 2009 I had a hand held one, that just had the slots. They told me that it was called a chain breaker, for working flat chain on farm machinery. I used it as a scroll tool, for awhile. :) Link to comment Share on other sites More sharing options...
orgtwister Posted August 28, 2009 Share Posted August 28, 2009 well it is for what ever you can use it for now that you have it one other thing i see you chisels there are mushroomed over i would grind them down if you had one of those break off and fly into your hand you would understand my concern Link to comment Share on other sites More sharing options...
dkunkler Posted August 28, 2009 Share Posted August 28, 2009 well it is for what ever you can use it for now that you have it one other thing i see you chisels there are mushroomed over i would grind them down if you had one of those break off and fly into your hand you would understand my concern Good eye orgtwister. Link to comment Share on other sites More sharing options...
double_edge2 Posted August 28, 2009 Share Posted August 28, 2009 That is a double ended fimjigamor with triple parralell perpendicular slots. Very rare. ye gads Arftist, your right!, ive seen one mounted on the lower arm of a flux compacitator. Link to comment Share on other sites More sharing options...
Kendrick Posted August 30, 2009 Author Share Posted August 30, 2009 It's interesting that you mentioned the chisels. A friend that came by on the same day you posted that admonished me as well. I guess I better dress them. I bought a bucket of punches and chisels at an auction. Haven't touched 90% of them. Thought I'd show you the rest so you can recoil in horror. Kendrick Link to comment Share on other sites More sharing options...
Muttt Posted September 1, 2009 Share Posted September 1, 2009 It's not so awful bad when they mushroom. But, when the mushroom starts to split and the turn into little pieces of shrapnel. They come off at like mach 2 and could easily put out an eye. Good luck ...... you'll wear down an entire 6 inch wheel grinding off all those mushrooms ..... LOL Mutt Link to comment Share on other sites More sharing options...
brianbrazealblacksmith Posted September 1, 2009 Share Posted September 1, 2009 That is true, but you should reforge the striking end, then grind, and you'll save your wheel or belts. That is normal wear and tear, and before it gets too far you should reforge them. You can even forge weld splits on tool steel relatively easily. Just don't burn it up. Tool steel forge welds very easily at lower temps than mild steel. Link to comment Share on other sites More sharing options...
Please sign in to comment
