hounddog Posted August 20, 2009 Share Posted August 20, 2009 here is my first knife its made out of a saw blade so how did i do? Quote Link to comment Share on other sites More sharing options...
Don A Posted August 20, 2009 Share Posted August 20, 2009 I like the shape of the blade. It has that 18th century "trade knife" vibe. Round over all of the edges on your handle, maybe carve a little curl where the "bird's head" comes around. A couple pins would look good; I like steel (finish nails). Several rubbed coats of tung oil or linseed will make that walnut look really good. Keep up the good work, Don Quote Link to comment Share on other sites More sharing options...
MRobb Posted August 20, 2009 Share Posted August 20, 2009 Very nice. Especially for your first. I agree with Don. A few more finishing touches. Keep up the good work! Mitch Quote Link to comment Share on other sites More sharing options...
Messerist Posted August 21, 2009 Share Posted August 21, 2009 Don and MRobb have it right. I like your overall design but if it were my knife I would work some more on the handle so that it feels good in the hand. You are doing very well for a novice maker and are in the right forum to help you develop your skills. Good Luck:)! Quote Link to comment Share on other sites More sharing options...
kevin (the professor) Posted August 21, 2009 Share Posted August 21, 2009 I like it for a first, too. Its good for any really. You should round the handles over and then take sandpaper (I use 2, 4, and 600). first polish to within an inch of its life vertically with each one, and then repeat same cruel sanding using the "shoe shine" method. Take a 2 inch wide strip of sand paper as long as you can get (about 11 inches if you have sheets). Fold strip in half for strength, and now shoe shine away by pulling the length of the strip back and forth horizontally across the kinfe handle (with knife sticking straight up and down and paper wrapped around half of handle in a U shape). When one side of paper loads, flip the strip. So, 200 up and down, 200 round and round... 400, " ", 600 " ". Then, rub well with finest steel wool you can get. Finally, rub with linseed oil, let sit about 5 with excess oil and then rub in vigorously. Then, slather lot of linseed oil on and let sit over an hour, rub vigorously, repeat several times, only increasing the time interval of the soak before rubbing each time. The heat from friction and rubbing with soft cloth is supposed to help linseed oil polymerize inside wood and form protective barrier. If you rasp, file, or belt sand the edges off of the handle and then give the finish treatment I described, you get a "traditional" finish. Also, it is MAGIC, one of the most enjoyable moments in knifemaking is the first time you put linseed oil on a freshly sanded handle. You won't know the true beauty of the wood until this moment, and then it jumps out. Kevin Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted August 21, 2009 Share Posted August 21, 2009 Kevin the pro.. has a great suggestion. Needless to say to be careful when working on a sharp blade. You may wish to make yourself a knife-vise such as this one that I made, as shown below. It allows you to work on a knife or blade safely at just about any angle. Yes, I have already been accused of spending too much time making tools. :D Quote Link to comment Share on other sites More sharing options...
