So after seeing Brian Brazeal's anvils I decided to set out on my own and try making something equivalent for my bladesmithing needs. Weight: ~240lb (With anvil stand ~377lb) Anvil (plate) Thickness: 4" Anvil (plate) Length: 13.25" Anvil (plate) Height: 16.25 Thickness of the stands bed: 2" Legs: 2.5" sq x .025" wall sq tubing Legs: 20dgs from vertical, 25dgs apart in back. Anvil stand walls: 1/2" x 13.25" with Two 6.5" x 1/2-13NC Grade 8 Bolts. Four 3/8x16NC Grade 8 bolts to immobil
