Material for Punches and Chisels
Hellom Bruce
Both Uri And Hofi Are Very Much Ok No Offence What So Ever.
My Feirst Name Is Uri The Femily Name Hofi Some Times I Sigen Withthe Feirst The Second Or Both.
As For The Tungsten Chisel; No Forging Is Possible. Only Grinding And No Heat Tritment Is Needed The Netueral Hrc When Cold Is 49-51
When Hot 45 And Because Ir Is Not Steel It Is Another Element There Is Very Little Friction Btween The Steel And The Chisel And It Will Cut In The Steel In The Tem Of 1700 Degrees Like Butter.
There Ar Two Types Of Tungsten -the Soft On That I Use And The Hard One That Is 70=72 Hrc Very Brital Whice U Can Not Grind Only With Diamonds Cald- Widia Or Hrd Metal Or The Proffetional Name '' Backed Carbides''
Best Regards
Uri+hofi= Uri Hofi
Very witty and gentle Uri. Namaste! Just think what that one or two tools made of the solid carbides or high speed air-hardening steels in action would have looked like to the Medieval smith with his wrought iron and semi-steel? MajiK, no doubt! I had never thought through the task of cutting hammer eyes; I dont make hawks, but read much from others of the travail involved and the varying methodology. The carbide chisel sounds like it might be a real break through for the hawkforger-people. They must be expensive for sure. You imagine you would have to have a well set up shop order the blank and grind it for you. Big nasty job. How much performance would be lost if one settled for a good high speed steel chisel instead? Your pick of steels. Thanks,
Fox Creek
Apprenticeman, the heat is one of the main issues for forging Tungsten. Its used for TIG welding because the welder simply will not get it hot enough to melt, while its easily melting steel. Tungsten has a higher melting point than any other element, and it doesn't melt till about 6,600 degrees F, if I recall correctly. To contain a fire like that, your forge would also need to be tungsten!
