Iron Dave Posted July 5, 2009 Share Posted July 5, 2009 Hello every body! Recently I bought my first Champion 400 blower and a very nice leg vise for my future blacksmith shop. The blower puts out a good blast of air and for $40 I couldn Quote Link to comment Share on other sites More sharing options...
Finnr Posted July 5, 2009 Share Posted July 5, 2009 The safest way is not to try. Is the inside badly rusted? If not I would give it a good scrubbing with diesel fuel and put it back together.Fill it up with a nice light oil and blow lots of air. The thing is full of oil slinging around so rust ain't likely to pose any problem internally. Finnr Quote Link to comment Share on other sites More sharing options...
bsiler Posted July 5, 2009 Share Posted July 5, 2009 I agree with Finnr, don't take it apart. In my opinion you don't need to fill it up with oil, it'll just run out. I have one and early on was told they are meant to leak. Just add a few drops of oil before you use it and a couple more during the day if you think about it. Billy Quote Link to comment Share on other sites More sharing options...
bsiler Posted July 5, 2009 Share Posted July 5, 2009 (edited) Sorry about the double post. Billy Edited July 5, 2009 by bsiler Quote Link to comment Share on other sites More sharing options...
keithgartner Posted July 5, 2009 Share Posted July 5, 2009 And dont sand blast or glass bead blast, grit will get inside, use a wire brush, or soda blast. ( dry ice chips ) Quote Link to comment Share on other sites More sharing options...
Iron Dave Posted July 6, 2009 Author Share Posted July 6, 2009 Well…. I was able to get the bronze spiral gear and small gear apart without damaging anything. I originally thought that the shaft had a sleeve on it because of how it looks, but I was wrong it’s all one piece. The inside has a lot of crud at the bottom some of it is rust, the gears had some of that crud and grit on them causing them not to run as smoothly as I would like. I agree with bsiler about not filling it up with oil, I cant see how it would hold any oil since there’s no provisions for some kind of seal, and I would think that a seal would only create more resistance. Originally I thought about sand blasting the whole thing inside and out and then painting it inside and out, But now Im wondering if a liberal coating of boiled linseed oil might be better. thanks for the help guys Quote Link to comment Share on other sites More sharing options...
