StephanFowler Posted April 29, 2009 Share Posted April 29, 2009 I Have a kniyon style hammer that I built a while ago roughly 100# head weight, 2 1/2 drive cylinder (Prince hydraulic) Parker pneumatic solenoid valve 80 Gallon Home depot special compressor when I first built it I had it running well, about 3 Hits/ second but I built it in my garage and didn't want to run it in the attached garage, so it's been sitting to the side until I can get my shop built out back. I fired it up the other day just on a lark and it's refusing to stroke properly, the head travels up and holds for 2-3 seconds then drops, repeatedly....... I replaced the solenoid and the selector valve and it hasn't made any difference that I can see. any ideas??? Quote Link to comment Share on other sites More sharing options...
Rodney Skinner Posted April 29, 2009 Share Posted April 29, 2009 if you had it setting for a long time the seals in the cylinder my be dry. try putting a very small amount of oil in one side of the cylinder. cycle a few times and see if it improves. do not put too much oil in or it will "hydrolic" on you. It would not funtion well like that either. Quote Link to comment Share on other sites More sharing options...
Rodney Skinner Posted April 29, 2009 Share Posted April 29, 2009 in my above post what I meant was the air could be leaking past the seals. You may need to replace your cylinder if the oil trick doesn't work. The above comments are assuming your air pressure, flow controls etc. are all o.k. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 29, 2009 Share Posted April 29, 2009 Use hydraulic oil for this as it won't attack the seals. If the seals are shot it shouldn't be hard to take the cylinder apart and replace it. It's probably an "O" ring. Good suggestion by the way. Frosty Quote Link to comment Share on other sites More sharing options...
StephanFowler Posted April 30, 2009 Author Share Posted April 30, 2009 I have an Oiler in the supply line so theoretically that shouldn't be the problem, it's possible though Quote Link to comment Share on other sites More sharing options...
Rodney Skinner Posted May 4, 2009 Share Posted May 4, 2009 The seals can still dry out if sitting idle for a long time. Also the oiler may not be adjusted correctly for your application. Just something to check out. good luck! Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted May 4, 2009 Share Posted May 4, 2009 Also, depending on the type of oil you ran i the oiler, it may have solidified a little to aid in the sticking. Can you test the oiler to make sure it is adding oil? If it is you may want to try and turn it up for a few minutes of cycles to rejuvinate the old oil. Quote Link to comment Share on other sites More sharing options...
nonjic Posted May 4, 2009 Share Posted May 4, 2009 might sound a bit obviuos but is your tup hanging up slightly on the slides??? worth putting a slosh of molly grease on them! Quote Link to comment Share on other sites More sharing options...
Rodney Skinner Posted May 22, 2009 Share Posted May 22, 2009 Have you had any luck getting your hammer to run correctly again? Quote Link to comment Share on other sites More sharing options...
