aametalmaster Posted April 11, 2009 Share Posted April 11, 2009 Antenna brackets. Made from 1" and 3/8" plate. 1 1/4" Holes bored in my lathe and welded with my MM185 w/CO2 and Inweld Dual Shield .035 fluxcore wire...BobE71T-1.pdf Quote Link to comment Share on other sites More sharing options...
Steel&Clay Posted April 23, 2009 Share Posted April 23, 2009 (edited) **** fine welds. Must have cleaned the ***** out of em' after that fluxcore. Edited April 23, 2009 by steve sells foul language Quote Link to comment Share on other sites More sharing options...
Torin Posted April 23, 2009 Share Posted April 23, 2009 (edited) fine welds. Must have cleaned the *****out of em' after that fluxcore. Not really is my guess. Dual Shield is not your normal fluxcore wire. You have to use it with gas, and the fluxcore is to make sure you get the gunk out of your weld. The slag just peels itself off of the weld, and it doesn't spatter all that much. Also for the wire he listed, you run electrode positive. It really is an easy wire to weld well with. I used ESAB Dual Shield 7100 Ultra to weld up my power hammer.ESAB Dual Shield 7100 Ultra Edited April 23, 2009 by steve sells quote language edit Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted April 24, 2009 Author Share Posted April 24, 2009 As Torin said not really. The slag just falls off. I found pcs a few inches long today in my drive and that was a week ago when i did it...Bob Quote Link to comment Share on other sites More sharing options...
