Grant Posted March 18, 2009 Share Posted March 18, 2009 Good Morning All I am in the process or rebuilding a small forge blower and need consultation. The blower seems complete, however there is a 1/16" of side play between the impeller and the case. This is enough play that the impeller shaft will clunk around within the case tapers when it is centered. When one moves the impeller shaft to either extreme the tolerance is fairly good on that side. This is by hand. I don't know how it acts when operated. I realize we are not rendezvousing in space, however I would like not to operate something that cracks and creeks more than I do. I do not want to limit anyone's experience or imagination, but I am hoping for a "cut off a small piece of your flannel shirt tail and rap it around the tapers, this will take up the slack and keep the oil in the housing" or "you are lucky most small blowers had larger tolerance out of the factory, clean it, lube it and run it," as apposed to "surface grind 40 thousands off the mating suffices and lap in new tapers". But, again I don't want to limit responses. Tks grant Quote Link to comment Share on other sites More sharing options...
arftist Posted March 18, 2009 Share Posted March 18, 2009 Oil the bearings every day that you use it, as it is a total loss system. Quote Link to comment Share on other sites More sharing options...
Grant Posted March 19, 2009 Author Share Posted March 19, 2009 Thanks Arftist - but there are no bearings. The tapered shaft you see in the second photo rides in a tapered hole in the cast case. Before I pulled it apart I thought I would find a straight shaft and either knural the guide or machine a brass bushing for it. But I found tapers. :confused: -grant Quote Link to comment Share on other sites More sharing options...
unkle spike Posted March 19, 2009 Share Posted March 19, 2009 A small piece of leather will work as a shim also....and grease it well with some light grease. I use white lithium grease in mine. You might want to de gunk the inside of the case, a smooth case will make for smooher air flow. Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted March 19, 2009 Share Posted March 19, 2009 You could simply try some thin metal washers as spacers and just keep them oiled. Quote Link to comment Share on other sites More sharing options...
Jerry W. Posted March 19, 2009 Share Posted March 19, 2009 I just acquired a blower just like yours. It was already apart and I thought the shaft was very worn. The bearings in the one that I have look like a poured babbit type bearing. I don't know if this was original or a later repair. Jerry Quote Link to comment Share on other sites More sharing options...
arftist Posted March 25, 2009 Share Posted March 25, 2009 Grant, sorry I didn't see your reply sooner. It the world of the old time machinist, cast iron is considered a bearing material. As long as there is no rotaional interference between the blower and the case, oil the bearings at every use and enjoy your working antique. Grease is not so good, as it traps dust and grit which is abrasive. Quote Link to comment Share on other sites More sharing options...
Grant Posted April 29, 2009 Author Share Posted April 29, 2009 Good Morning All I believe I Quote Link to comment Share on other sites More sharing options...
JamesBBrauer Posted April 29, 2009 Share Posted April 29, 2009 I refurbed a blower, but sold it to get cash for kaowool and plumbing parts for a gas forge. My coal forge has an electric blower. But anyway, if you get this blowing and aren't happy with the axial runout you might try a drill bit shaft collar to lock the position. I've used those on a couple of my contraptions, and they work nicely. Quote Link to comment Share on other sites More sharing options...
Grant Posted May 12, 2009 Author Share Posted May 12, 2009 Good Morning All Thanks to everyone for the help. With a few flat washers for spacers on the two severally worn shafts, she is alive, well, and surprising robust. Who da thunk that little four paddle blower would work so well? Anyway, thanks again. -grant Quote Link to comment Share on other sites More sharing options...
Charlotte Posted May 12, 2009 Share Posted May 12, 2009 Good deal! Glad that we have revived another failing blower. Congratulation on a job well done.! Quote Link to comment Share on other sites More sharing options...
argent Posted May 25, 2009 Share Posted May 25, 2009 Or, you could use some disks cut from a kitty-litter bucket to take up the end play, just dis assemble the outer plate, place them on the out-board side (or the end that rubs) and voila', new bushings!! Quote Link to comment Share on other sites More sharing options...
