Tim Lonnee Posted March 15, 2006 Share Posted March 15, 2006 I was working on a guard the other day and figured i would try something. I took a hunk of rubber tubing and slid it up the tang to hold the guard in place while the J B weld set.Worked just fine. Kept it at a 90 degree and slid off easy when it was dry. I have seen fancy home made jigs out of steel but for someone who can't make one out of steel, try this. Worked out perfect on 3 blades so far and no problems. Quote Link to comment Share on other sites More sharing options...
will52100 Posted March 18, 2006 Share Posted March 18, 2006 Good tip, I'm working on one tonight and probably most of tomorrow and will try it. I made a steel one to use for soildering, but like the tube idea as I try for a soilderless fit now. Quote Link to comment Share on other sites More sharing options...
