309 -
Everything posted by jcornell
While I really like the Huston style folding knife, it has a drawback - it's not very safe in the pocket. So I set out to tinker with the design. I originally thought I'd bind the blade to the frame with a permanent rivet, but ended up using a small machine screw and nut. This one is made with a spring steel frame and blade. The spring is an old McPherson Strut donated to me by one of my daughter's friends. He ended up with the knife as a thank-you. The next variation was made with a spring steel blade (toyota) and a mild steel handle. This is inspired by a Chapman design, but I went through a number of prototypes before I had something I was happy with. This is my every day carry knife. The frame is made from the wire that holds up political signs - it's mild steel that welds nicely. There's primary elections this month, and as I drive around town I tell my son that I live in a wonderful country where people deliver steel to my neighbor's yards. I'm a noob when it comes to grinding blades, so a year from now I'll probably cringe when I see this blade, but it works for now. Heat treated and quite sharp.
Another cheap solution is to flip the work over while you still have some heat and planish. The working side of the piece is way more bumpy than the side that's against the anvil (assuming that you have a flat anvil face), so turn the piece over and tap the flat side lightly to use the anvil face to work those bumps flat before returning the work back to heat. It's a lot easier to do it now, than to do it later with a sander, grinder or file. J
1/4-28 if you're planning on using a mig-tip - but be sure you buy the correct size mig tip!
I do some work on junkyard metal, primarily spring steel, which more often than not is 5160. It makes nice punches and usually turns out a decent blade as well. These odd scraps you've found will require a lot of work to shape into useful pieces, and may or may not be something that can be hardened or tempered. Better to build your skills with stuff that you know will behave. Fuel and time are limited.
I've purchased Schedule 80 nipples from McMaster Carr and Grainger. McMasterCarr ships quickly, and Grainger will ship to one of their local stores (which in my case is about 15 minutes from my house.) http://www.mcmaster.com/#4550k117/=rnw4kr
In keeping with the dragon theme, you could take a bolt with two washers and have the threaded end sticking out, using the washers to close off the hole. Personally, I'd just leave them there - the kaowool, once you've used rigidizer, will suffice to block these holes.
"Honest, Officer, I put that anvil up on the saw horse because I wanted to put rustproofing paint on the bottom. I never knew that it would fall over and pin someone to the ground. I was away at Quad State for several days and I didn't find that poor man until I came back..."
Hugh McDonald Steel Rolling Mill
jcornell replied to jimbob's topic in Machinery General Discussions
Anvilfire says that their online ordering is broken right now, but if you call you should be able to order. I bought the plans a while ago and put it into my "I need to do this someday" file. J -
>>> I mainly want to do bladesmithing but this forge looks like it will kind of restrict me because it doesn't look too big inside(I may be wrong). But most gas forges look like the will stop me doing anything too big(which I probably wont.. but just in case). My main forge is made from a 3# coffee can. The limiting factor is the size of the pass-through hole in the back. Yes, if I were doing 8" spirals, I'd need a larger forge, but I've made railroad spike knives, knives the size of a machete and other odd bits of tooling and jewelry in an itty-bitty forge. The mistake of most beginning smiths is to go too big - because of course "I may make a sword." By the time you get the skills to do bigger stuff, you'll be able to justify a second (third, fourth) forge, or you'll go over to visit a neighbor smith and use his coal forge.
At the back of Porter's book on forge burners are pictures of a 1/4" and 3/8" NA burner. I've built a couple of 1/2": burners, and that was as small as I wanted to go.
Home build induction heater
jcornell replied to Daniel.85's topic in Induction Heating, Oil forges, etc
I for one would stand in line to order a reasonably priced kit. As much as I like my propane forge, the notion that I could move things into my garage is very, very attractive. -
He quoted $110 to me this week - PM me for contact information.
Melting and recasting stainless steel?
jcornell replied to SCI-FI's topic in Smelting, Melting, Foundry, and Casting
Wouldn't it be easier to make a cross using SS keystock? I just made a small pendant sized SS cross for my college-aged daughter. Melting down a tea kettle to make a cross seems to be like burning the garage down to bake a ham - yes, it can be done, but there are easier ways to do it. -
Trying to commercially make an anvil
jcornell replied to kawvalleysteel's topic in Anvils, Swage Blocks, and Mandrels
Here's an anvil that Glen Stollmeyer is making in Taiwan (I don't think he's selling them). Given the size of your stock, I'd actually prefer this design - I'd use a bick of some sort if I needed turning that I'd do on a horn. Keep us posted with your progress. -
bimetal blades for Damascus/pattern weld?
jcornell replied to jcornell's topic in Alchemy and Formulas
If it breaks that's a good thing, right? -
I have a Milwaukee Portable Bandsaw and have kept the old bimetal blades as I replace them. Is it possible to use these for pattern weld (using a contrasting steel, like strapping) or is this project doomed?
Check out Thermal Art Design. They call their burner the JF#1 - I've seen them in action, they seem to be a nice burner, and the people who have them say nothing but good things about them. Me, I make something like the Porter burner - it's not as fancy as the hybrid burner, but it's not as pricey either.
Do your burners have flares?
Taking others' ideas...is it OK?
jcornell replied to billyO's topic in The Business Side of Blacksmithing
Back in the 1970's, before Disco, I was somewhat active in pottery. Many of my fellow students had trained under an artist (Macanalan) who used to be in town, but then moved to a studio upstate. Everyone who'd trained under this fellow made mug handles in the way that they'd been trained - they made their mugs with Macanalan handles. I never spent a minute with Macanalan, but I learned second and third hand from his students, so I too made mugs that way. None of us (that I know of) tried to pass our stuff off as genuine Macanalan, but it was obvious to some who'd been his student. Likewise, Mark Aspery has put out his marvelous books, and many of us learn from him how to make Aspery-style wizard hooks. Brian Brazeal has made his marvelous videos and trained us how to make horse heads. There's a little bit of every smith that I've ever worked with in my work, as I try to learn something from every smith I see. I'll never make a knife as pretty as Owen Bush, but I like how he made loop handles on his Viking knives, and I now make all of my loop handled knives using that technique. Do I try to pass my work off as that of another smith? Nope. Do I say "I was inspired by Owen Bush to make my handle like this?" Yup. I have no problem with people selling horseshoe hearts and horsehead bottle openers - we know where the technique came from. -
I'm fairly certain that a blade that's been repaired in the manner Steve described would not be allowed in a competition. These look to be non-electric (hard to tell from the photo) so they wouldn't be used in competition, only in practice. The steel alloy used in fencing foils is rather complex and the heat treating is beyond complex. My son was fencing with me a few years ago and the tip of his non-electric foil shattered. Owner of the academy stopped us right there and took the foil back to his office for a replacement (on the house). Foils are supposed to bend, bend and then bend some more. A foil that breaks is dangerous to the fencers. By the way, Steve, nice job.
Somewhat of an auto scrap guide
jcornell replied to Admanfrd's topic in Blacksmithing, General Discussion
I'm somewhat fond of OTS steel (old toyota spring) because my neighbor donated a full set of coil springs to me and then a fellow at church gave me the leaf springs from an old toyota pickup truck. It may or may not be 5160, but it sure acts like it. -
If building the "no welding easy forge" on Larry Z's site, I'd do one of two things: 1) I'd go to three inches of insulation (to increase the efficiency, but more importantly, to reduce the volume); or 2) I'd move from a 3/4" burner to a 1" burner. In either event, I'd use rigidizer on the ceramic wool and then coat the wool with a reflective/refractory coating. People love the Chili forges, and I've noticed that their current Diablo stock burner is approximately 1" - which means the forge is getting a healthy number of BTUs, more than it would get from a 3/4: burner (they used to use something like Larry Zoeller's 3/4" sidearm burner.) J
a ball valve to do a quick shut-off of fuel to the burner is a very good idea, The gauge is nice, but not entirely necessary - eventually you'll do it all by eye and ear - what the flame looks and sounds like. It may be helpful to know that a particular steel welds well at 15 psi versus 20 psi, but I don't know how really accurate the gauge is in reality. I've used both the Bayou Classic and the High-Temp Tools/Zoeller Forge set-ups. Long term I trust the more expensive regulator more, but I can't articulate why that is - the Bayou Classic works just fine. I wouldn't use the Bayou Classic without a ball valve for a shut-off though.
Here's a few projects that I've done this Christmas. These are a variation on the Frederick Christophe (or Christoper) cross. The larger crosses are made from 3/8" square rod with the circle made from 1/4" square rod. Here's how it's made: Slit the larger stock for the cross. Forge weld the smaller stock into an appropriate diameter circle. Unfold the cross long ways, slip the circle over the shorter arms and then open the smaller arms. The right-most cross is my "proof-of-concept" piece, and my wife liked the unfinished look, so I kept this one around, but I'm showing it here mainly to give a hint as to how it's put together. For most of the ones that I made as Christmas gifts I then forge welded (or attempted to weld) the circle into the cross. After that, I used the cross pein to spread the ends of the cross arms, then used a ball pein to dimple the surface all over. The smaller cross uses 1/4" square rod stock for the cross and the circle is made from that nifty wire used in election signs (I harvest them every election) - it's a little bigger than 1/8". Some of these I then welded like the larger crosses, but I liked them more in the small size as shown. These were given as Christmas ornaments, with a slender red ribbon attached as a hanger loop. This gadget is what I call "the blacksmith's hotpad." I was fooling around with a piece of #3 rebar I picked up from the junk left over at my church from a construction project. I made a push stick with hooks on the end to pull and push the oven racks when putting things into and out of the oven. The hook is also useful to snag the lip of some pans, pulling it out far enough to get a good grip with a conventional hot-pad. When I do demonstrations one of the common questions is "do you ever get burned?" and my common answer is that I burn myself far more often in the kitchen than I ever do at the forge (which happens to be true). Rebar has its own texture, which does interesting things when you twist it, so I twisted all of the models I made this year.
I'm wondering if Vermiculite would work in a gap between the hard and soft bricks?
