Azur, I can't think of any reason the shape would have to be a triangle. If the 'cube' (square) is working for you and easier to make, stick with it.
I think you're getting closer every day and will soon have a good shop.
Mine runs on a 2.5 cast iron pulley. I use 2 'B' vee belts tho I think 1 would be fine. My belts run on the outside surface of the idler. On my hammer the idler/clutch is to the rear of the machine. I worked out the speed years ago when I set it up. Think it was in the 350 rpm range. My motor is mounted low on the right side. Will take pictures tomorrow if you want.
Ha!
only part 1 of a rebuild is available but it may be of some help. http://www.anvilmag....smith/011f2.htm
If I remember right I recall that Sid had some tooling available for rent or ? to help with pouring new mains.
I was replying to Tim's comment that.... "This thread count results in a travel of about a 1/4 of an inch per turn of the handle.'
He did not say *jaw travel" but *travel*. In this case 'travel' would be assumed to be 'travel' of the thread since that's what we were 'talking' about. Jaw 'travel' is another issue.
I have seen 'acme' threaded rod and acme nuts but never 'square' threaded rod or nuts. Can you provide a source?
not to quibble but...
three threads per inch would be 1/3 = .3333 etc.
closer to 5/16" (.312) per full turn. or 21/64" (.328 to be completely ridiculous.)
sorry. :wacko:
it will be easier to find a replacement vice screw if you measure the major diameter and the number of threads per inch of your existing screw. there are no 'standards' when it comes to these vices. not that I know of anyway.
unlikely that you will find a similar screw floating around out there without a vice. a shot in the dark. but nothing wrong with trying.
he should be embarrassed. and what's with the 'bare chested' look? second vid this week with no shirt? what's that? and the 'music'?
too funny. too dumb.
just going from what has been posted I am guessing that after the 'new' plate and the top of the anvil were milled (and maybe ground) flat, that holes were drilled and tapped in the anvil. then matching thru holes with a large countersink were drilled in the new plate. then single ended studs were threaded into the anvil. then the plate was placed over the studs which were then heated with a torch and riveted over filling the countersink to hold the new top plate on. the surface could then be ground removing any remaining 'head'. if done well it would be hard to see the 'heads' unless someone pointed them out.
seeems like it could work but if it was me I would look for another anvil. they aren't that hard to find.
but what do I know? B)
Kevin,
I am in southeast minnesota (Winona County) and may be able to help you out on a nice coal forge. send me a private message if you're interested and I'll give you my phone number.
Bob
Your drill looks pretty light duty. If you start out with smaller drills and work your way up you might be able to drill a 1/4" (about 6 mm) hole.
I would look for an electric drill.
Good luck Azur.
